20 Most Recent
Polaroid iZone 300 Digital Camera Questions & Answers
Will not turn on
Either the battery is not charged or no good or the camera has died on you. Will the camera work off of the charger? It should. if it is good.
Users Manuel
Go to polaroid.com, select digital cameras and follow the prompts. Eventually you will be able to select the manual for the izone300-301. Peace
Does not hold a charge
Hello. When a camera will not hold a charge you must replace the rechargeable battery. Take your camera into a local camera shop along with the charger and have them test both the battery and the charger. This is generally a free service. Joe
please rate my answer as very helpful. thank you.
My camera has frozen up!!!
I found instructions posted on the internet that showed the reset button, I pushed that button and everything was back to normal.
The camera says memory full
You probably need to format your card. Look thru the menu on your camera...there should be a place on the help menu, which allows you to format your card.
What does sd procected mean
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I cant find my disc to help load the pics from the
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
How do i get my polaroid to download pics too my
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
