20 Most Recent
Philips PM4S Remote Control Questions & Answers
Remote help
http://www.urc.philips.com/find_baseCode.asp?setupDocId=554&efsetupDocId=-1&asDocId=554&readDocId=-1
Lost directions and code for setup
Here's how:
Turn on the electronic you will programming the code for.
Press and hold the CODE SEARCH button until the red indicator stays on, then release the COE SEARCH button.
Press and RELEASE the desired mode button (TV, VCR, etc.). The red indicator blinks quickly, then stays lit.
Enter the 3 digit code from the code tables.
With the device on, press CHANNEL UP on your remote. If the device responds, no further programming is required.
(I have the code chart, if you tell me what components you have, ie reply to this post, I will give you the proper codes.)
Philips Universal Remote (PM4S)
i soon found a website with a working 4 digit code for my tv. i did not program my vcr or dvd yet, but i will try later.
*fell
Need code for insignia tv
Well, if it's a new product on the market, it might not be listed yet. but good news, in the listing of my new universal remote controle, they give some codes for you: 0911, 0520, 0323, 0115, 0914, 0213, 0318, 1416, 0247, 0504.
Program tv
Just a tv, (not a combo unit) the codes are as follows:
002
006
007
018
103
107
114
310
312
502
601
704
803
806
810
901
911
Press and hold the CODE SEARCH button until it stays lit, then release. Press and release the deired mode button (tv) and enter in a code. If the code is valid the red light will go out. You are done, if not, try another code by starting over.
Universal remote code
Programming a Device using Code Search:
- Manually turn ON your device (TV, VCR, Cable Box)
- Press and "HOLD" CODE SEARCH
- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
- Release CODE SEARCH.
- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
- Once the device turns off, press and release ENTER.
- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Universal remote
well if you dont have the code book then ur screwed, theres maybe a chance you could find itonline but i doubt dat. i suggest you buy anew one which is 5-20 dollars. i payed 10 for mine
I need a code
RCA tv codes for PM4s:
704 002 406 007 011 611 811 312 514 720 411 102 502 601 835 901 103 803 211 912 114 519 320 420
Help
No code on the factory supplied code sheet for a Trutech brand tv. Is it a different brand in the US?
