20 Most Recent
Sony Vaio VGN CR353 Laptop Universal AC Adapter 18-20v (AC22VPNB4VRFQ) Questions & Answers
Sony vaio vng cr-353 slow fan
Generally there are a number of reasons causing your Sony Vaio laptop or
desktop PC running slow or freezing. Common ones include lack of free
disk space, registry corruption or redundancy, overload startup
programs, virus attack, fragmented hard drive etc. There are
manual ways to get all those issues fixed but it costs time and energy,
and most importantly it needs technical skills. So I'll recommend a
quick yet easy speed up solution, as you can see here:
http://www.sonyvaioslow.com/Regards!
Unable to connect to internet despite connection confirmed
Improve the FixYa experience for everyone by voting.I'm going to provide you with some generic approaches in an attempt to solve your problem.First: Microsoft will perform a complete systems check for you in three clicks with their FixIt app.
CLICK HERE and Microsoft will fix (repair) any Windows related problems that might be causing your problem.Second: It is important to connect the modem to the router before you configure the modem in order to verify communication between them. If the cabling is incorrect, the rest of the process fails.As a rule, external modems are built with a female data communications equipment (DCE) DB-25 port for connection to a controlling device such as a PC or a routerConnecting the modem using the network cable to the wrong port of the router (other than the WAN port) is easy to identify. You can easily troubleshoot the problem. In some cases, you may correctly setup the wireless router connection but you use the wrong cable type in connecting the modem to the router. Cross type UTP cable must be used in connecting the Ethernet port of the modem to the WAN port of the router. But this is not always true. Today, many types of wireless routers (and any LAN Switches) embedded their Ethernet ports (either WAN or LAN ports) with Auto-sensing type port (auto-MDIX LAN). It means that you can use either cross-type or straight-through-type network cable for the Ethernet port connections. The system will detect the cable type and automatically adjust the ports signal accordingly.
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
Sony cfd-s70 Will Not Read CDs
There are a few possible causes for a Sony CFD-S70 CD player not reading CDs. Some possible issues include:
- Dirty or damaged CD: Make sure the CD is clean and free of scratches or damage.
- Dirty lens: The lens that reads the CD may be dirty or dusty. A cleaning disc can be used to clean the lens, or you can use a soft, dry cloth to gently wipe it clean.
- Faulty lens: If the lens is faulty, it may need to be replaced.
- Faulty CD mechanism: If the CD mechanism is not working properly, it may need to be repaired or replaced.
- Power Supply Problem: Make sure the power supply is connected and the power outlet is working.
- Firmware issue: A firmware issue could prevent the CD player from reading CDs. You should check the Sony website to see if there are any firmware updates available for your specific model.
If the problem persists after trying these suggestions, it is recommended to take the device to a professional repair service or the nearest Sony Service center.
Sony TRV 740 E Fehlercode C:31:40
Der Fehlercode C:31:40 bei Sony Camcordern deutet auf ein Problem mit dem Motor des Kassettenfachs hin. Es kann sein, dass der Motor blockiert ist oder dass es ein Problem mit den Sensoren gibt, die den Status des Kassettenfachs ?berwachen. Um das Problem zu beheben, k?nnen Sie folgende Schritte ausprobieren:
- Entfernen Sie die Batterie und das Netzkabel des Camcorders und lassen Sie das Ger?t f?r einige Minuten ausgeschaltet.
- ?berpr?fen Sie das Kassettenfach auf lose Teile oder Fremdk?rper, die m?glicherweise blockieren k?nnten.
- Versuchen Sie, das Kassettenfach vorsichtig zu schlie?en und zu ?ffnen, um zu sehen, ob dies das Problem l?st.
- Wenn das Problem weiterhin besteht, k?nnen Sie versuchen, das Kassettenfach mit Druckluft zu reinigen, um m?gliche Blockaden zu entfernen.
- Wenn alle diese Schritte fehlschlagen, kann es ein mechanisches oder elektronisches Problem sein, das eine Reparatur durch einen qualifizierten Techniker erfordert.
Es ist auch m?glich, dass das Problem durch eine defekte Cassette verursacht wird. Wenn m?glich, versuchen Sie, eine andere Cassette auszuprobieren, um zu sehen, ob dies das Problem l?st. Wenn das Problem weiterhin besteht, liegt es h?chstwahrscheinlich am Camcorder selbst.
Sony Playstation 3. Infamous intro doesn't load
- Restart the console: Sometimes, restarting the console can resolve software issues and help the game load properly.
- Check for updates: Make sure you have the latest firmware installed on your PlayStation 3, which can be done by navigating to the "Settings" menu and then to "System Update".
- Check the game disc: Make sure the disc is clean and free of scratches or damage. If the disc is damaged, it may need to be replaced.
- Reinstall the game: Try uninstalling the game and reinstalling it from the disc. This can help resolve any corrupt data that may be causing the issue.
- Try a different game: If the issue persists, try playing a different game to see if it's specific to Infamous 2 or if it's a general issue with the console.
