So, if I am understanding you right. As you are talking on the mic you are cutting out as if it is shutting down. If this is the case I would adjust your settings. It sounds like it is clipping from maxing out the input. A protection is cutting you out. Let me know if this is not the case.
As you have written, it sounds like a short or a frayed wire. That is what I would have thought. It could be that the terminal wire has dry jointed and come away from the mic head. You could buy a cheap £15 head set just to check that it is the cables. I use a similar system for a glass blowing studio demonstration area and I am constantly buying replacement head sets. Its a shame there is no complete wireless system on the market. It is always the connections between the bodypack and the headset that are the weakest link.
Theoretically you should be able to connect an MP3 player to the bodypack to prove there isnt a problem from there-on. (I have never tried this but I am now intrigued as to whether it would work)
Its a bit of trial and error and you seem to be following the same path that I would. The only other problem I have had is the aerial on the body pack. I would never have thought such a small aerial could cause popping sounds etc but I have also seen this to be a problem in the past.
Hi, when loud screeching sounds and static is are heard on sound systems in most cases it is as a result of poor wire connections to the speakers. Check the wires to the speakers most likely the screeching and static is coming from those.
Also static could also be caused by mobile devices being close to the receiver. Mobile devices such as internet modems and mobile phones as well as radio transmitting devices could cause static and screeching.
Hello Sampson
People ask questions. Experts answer them. No one get paid, people answer just for the joy to be able to help others.
People who use AI Chat GPT to answer, people who answer just for points get deleted. Points are for fun.
It isn't a 'program', it is a peer to peer self help website.
ADMIN Andrew
There could be several reasons why your Samson Airline CR77 receiver is not producing any output:
Volume levels: Ensure that the volume levels on the receiver are turned up and not muted.
Output mode: Check if the output mode on the receiver is set to the correct mode (balanced or unbalanced).
Cables: Make sure that the cables used to connect the receiver to the sound board are functioning properly and are plugged in correctly.
Interference: Check if there is any interference from other wireless devices operating in the vicinity. This can cause signal dropouts and affect the receiver's output.
Dead batteries: Check if the batteries in the receiver are charged or need to be replaced. A low battery can cause a drop in output.
If none of these solutions work, you may need to contact Samson's customer support for further assistance or consider taking it to a professional technician for repair.
Any that can plug into the unit. The quality of the sound will depend on what you are willing to pay for the microphone.
I would take the unit to a shop that sells microphones and they will be able to get you a right one for the unit.
Hi, have you tried the G-Track Pro on another computer, to see if it repeats the fault?
I sent you the link so you can download the user manual of your Samson
I hope you can solve the problem
Greetings Franco Dosil
Hola, has probado el G-Track Pro en otra computadora, para ver si repite la falla?
Te env?o el link para que puedas descargar el manual de usuario de tu Samson
Espero puedas solucionar el problema
Saludos Franco Dosil
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&p=2&thid=27347935#
