20 Most Recent
Vivitar ViviCam 3625 Digital Camera Questions & Answers
I believe your CCD chip has gone bad. If all other functions are working, it is definite the chip at fault. Unfortunately, the chip is not available for replacement. Also the repair cost may out weight the replacement cost.
I lost the software that
You don't need to use the Vivitar software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I need software for my 3625 vivi cam
You don't need to use the Vivitar software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Where can i get software
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Manual for x024
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/236/ViviCam_X024_Camera_Manual.pdf
I had my camera stored for last few years and
You can take the SD card and try it on your PC, if this wont read then there are errors on the card as it is not detected.
There is a tiny protect swittch on the side of the card , please check the psottion of this switch and see if this has created the issue. If not place the camera ON for some time as the set was stored for some time. The fault might clear if the electronics come back to original state when energised for sometime.
Not Recognized
install the a driver of your camera, so the pc will recognized what device that plugged.
usually, the cd driver included when you buy the camera.
Wont repower
Hello
Thank you for using FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Vivicam3625
the problem is with windows vista dump it and reload win xp pro or spend alot of money 'fixing ''vista
