20 Most Recent Sanyo DC-AVD8501 System Questions & Answers
Need unlock regional code for
Hi jimhamilton,
Try the following Link to get access to over 6 thousand four hundred Unlock Code Solutions
http://www.videohelp.com/dvdhacks
Somewhere on this list you should/will find you exact model to 'Unlock'
Best of luck,
techbuff
3/12/2011 6:22:26 PM • Sanyo DC-AVD8501... • Answered on Mar 12, 2011
2answers
DC-AVD8501 wont stay on
Mine did this last year, turns out there was some problem with the soldering on the circuit board. Take it to be looked at, easy to be re-soldered and cost me about £50.
8/16/2010 3:41:24 PM • Sanyo DC-AVD8501... • Answered on Aug 16, 2010
How much would it cost to service a 1960's sanyo reel to reel video recorder?
Video recorder? Please state model number.
12/10/2023 8:35:38 AM • Sanyo Audio... • Answered on Dec 10, 2023
I cannot get sound on my Sanyo RM-7024 cassette/radio player. What do I need to do?
from description given the unit is defective.
7/14/2023 5:26:09 PM • Sanyo Audio... • Answered on Jul 14, 2023
Sanyo TRC 1149 winding and playback faults
Hi,\015\012\015\012I'm sorry to hear that.\015\012\015\012This is a common fault on cassette decks and can be caused by a number of things.\015\012\015\012The most common is the motor being seized or worn.\015\012\015\012If the motor spins when you touch the belt then the problem lies in the drive mechanisms.\015\012\015\012There is a good chance that the drive belt has perished and needs to be replaced.\015\012\015\012If the deck is drawing too much current when you switch it on the fuse will blow.\015\012\015\012If the fuse is fine and the deck runs for a few seconds before cutting out then the problem could be one of the capacitors in the power supply.\015\012\015\012If the deck is more than 10 years old then it may be time to replace the capacitors.\015\012\015\012You can do this yourself if you are a little bit handy with a soldering iron.\015\012\015\012That's about it really.\015\012\015\012
11/5/2022 1:11:06 PM • Sanyo Audio... • Answered on Nov 05, 2022
I need the User Manual for the Radio Clock SANYO RM 5060
https://www.manualslib.com/manual/1069169/Sanyo-Rm-5090.html
7/10/2022 2:34:15 PM • Sanyo Audio... • Answered on Jul 10, 2022
Hi i have a sanyo tp825du turntable and the platter keeps spinning when tone arm is at rest. What is the issue that causes this and what do i need to do to fix it. Thanks guys.
When the tone arm returns to its base it should contact a small micro switch which turns off the motor. Going underneath the platter you should find the switch, either bent out of place or broken.
6/5/2021 3:43:35 PM • Sanyo Audio... • Answered on Jun 05, 2021
Cannot play wmv or MP4 files - SANYO DMC 2040
You most likely are not meeting the specs required by the player. Check the manual on the cd for the specs the player can resolve or use the converter on the cd to convert your mp4's wmv to meet the specs.
5/7/2021 10:46:02 AM • Sanyo Audio... • Answered on May 07, 2021
Pairing Sanyo tv with wireless speaker? Please
Is your tv compatible with wireless speakers?
3/7/2021 11:57:57 PM • Sanyo Audio... • Answered on Mar 07, 2021
I have a Sanyo universal remote and a durabrand home theater ht-400. How do I program the remote for it?
Use code search on your Sanyo URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
12/21/2020 4:48:53 AM • Sanyo Audio... • Answered on Dec 21, 2020
I have a sanyo cassette deck model Rd r60 circa 1983. I have purchased new belts for the deck due to the old belts having become liquid. I have cleaned all the pulleys but need to replace the belts with new ones. Does anyone have a belt diagram of the machine or know where I may find a diagram? Any help would be greatly appreciated.
There might be a diagram but I haven't seen any belt fitting diagrams at all, merely the odd exploded view. Replacing cassette belts is as much fun as a jigsaw puzzle - you keep removing screws and parts until you can fit the belt and then you reverse the process...
7/4/2020 8:03:49 PM • Sanyo Audio... • Answered on Jul 04, 2020
What is the FM ANT and how do we use it on a Sanyo DC-DA1460M
Hello Hannes, FM ANT, is the connection of the antenna to receive FM radio stations (Frequency Modulated) Here you can connect a cable of approximately 1 meter, and use it as an antenna, depending on where you are, rural or remote areas. the city, you might need an external antenna, similar to those used for analog TV reception I sent you a link to download the user manual of your Sanyo Greetings Franco Dosil Hola Hannes, FM ANT, es la conexion de la antena para recibir estaciones de radio de FM (Frecuencia Modulada)Ahi pedes conectar un cable de 1 metro aproximadamente, y lo usas como antena, dependiendo de donde te encuentres, zonas rurales o alejadas de la ciudad, podrias necesitar una antena externa, similares a las usadas para recepcion de TV analoga te envio un link para que descargues el manual de usuario de tu Sanyo Saludos Franco Dosil https://mans.io/files/get/499596 https://mans.io/item/sanyo/dc-da1460m https://elektrotanya.com/sanyo_dc-da1460m_micro_component_system_sm.rar/download.html
6/18/2019 6:11:05 PM • Sanyo Audio... • Answered on Jun 18, 2019
How do I repair 3 cd player on my sanyo dc-D37u decks dont come out
Hello Walter, what do you want to repair in your Sanyo DC-D37U, the mechanism of the CD player? I sent you the link to download a Service Bulletin of those mechanisms I hope you can repair it, comment the results Greetings Franco Dosil Hola Walter, que es lo que quieres reparar en tu Sanyo DC-D37U, el mecanismo del reproductor de CD? Te envio el link para que descargues un Boletin de service de esos mecanismos Espero puedas repararlo, comenta los resultados Saludos Franco Dosil https://www.dtforum.info/index.php?action=dlattach;topic=7137.0;attach=9887
6/2/2019 4:56:17 AM • Sanyo Audio... • Answered on Jun 02, 2019
New Sanyo TV put in with existing cable box using HDMI cable plug the tv in and it won't load the channels? The cable box recognizes the Sanyo. Why aren't the channels loading?
Hi Paula, check the HDMI input, on the Sanyo TV, where the cable box is connected, it is assumed that the channels are loaded in said box Hola Paula, verifique la entrada HDMI, en el televisor Sanyo, donde esta conectada la caja de cable, se supone que los canales est?n cargados en dicha caja
4/15/2019 12:08:20 AM • Sanyo Audio... • Answered on Apr 15, 2019
Popular Tags
6 questions posted
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Audio Players & Recorders
Most Popular Question
need unlock regional code
  • Audio Players & Recorders
