20 Most Recent Sharp 27L-S100 27" TV Questions & Answers
find the setting button on remote and follow the instruction go to timer on/off and switch it to the off position.adrian,,,,
Sharp 27L-S100... | Answered on Feb 12, 2015
If you want to use that tv to receive broadcasts over the air, yes, you will need a converter box.
Sharp 27L-S100... | Answered on Oct 29, 2014
Could be a failing power supply
Sharp 27L-S100... | Answered on Apr 11, 2014
Short circuited component/s at the main board. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Sharp 27L-S100... | Answered on Jan 27, 2014
I have some repaired unit with the same problem as what you've encountered right now.
It is commonly caused by faulty electrolytic capacitor on the low voltage power supply, mostly on the regulator section. Leaky capacitor will affect the performance of the power supply that's why it is hart to power up.
It is not DIY and quite technical so I've advice you to look for a qualified technician or send it to repair shop to isolate the problem. This is fixable.
Thanks for using fixya.
Please rate my help.
Sharp 27L-S100... | Answered on Jan 17, 2011
Hello
Three digit universal remote code for Sharp are:-
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote code for Sharp are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Sharp 27L-S100... | Answered on Dec 15, 2010
acording to the Sharp product specs. No it does not.
Sharp 27L-S100... | Answered on Sep 14, 2010
find another TV, VCR (many around now), or other cable using device and exchange - 7 or so screws on  back of tv come right off and expose lower interface where cable jack is.  remove wires, solder salvaged unit in and it works....  Be careful when removing back of tv -  you can pull other wires when doing so.
Sharp 27L-S100... | Answered on Jun 02, 2009
Hello Ann, I will try to help you, well if your for sure about the Manufactur date on the T.V., then yes you will need a digital converter box, also it is suggested to have an outdoor UHF/VHF antenna with coax to attach to your converter box, the old rabbit ears aren't suggested. I hope this helps in getting you prepared for Feb. 19, 2009 when all T.V. stations broadcasting will convert to the new signal. Thank You and Have great day.
Sharp 27L-S100... | Answered on Jan 15, 2009
Sharp has issued a recall on this model. Go to www.sharpusa.com/tv to have it repaired.
Sharp 27L-S100... | Answered on Oct 24, 2008
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Sharp 27L-S100... | Answered on Mar 07, 2008
Sharp 27L-S100 27" TV Logo
Popular Tags
23 questions posted
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
sharp 27l s100 manufactured 3 1999 need
  • Televison & Video
