20 Most Recent Leadtek WinFast PVR2000 Video Capture Questions & Answers
0answers
Download edirol ua-700 usb audio
http://download.cnet.com/dw90usb-device/3000-2120_4-62795.html
http://download.cnet.com/leadtek-winfast-vr300/3000-2108_4-82870.html if these driver packages are not right http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for (be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
8/12/2011 1:28:23 AM • Leadtek WinFast... • Answered on Aug 12, 2011
2answers
Hi im a doctor doing cardiac ultrasound and we
There are a whole load of Video latch on devices for a PC, which, in my view are fairly useless.
I'd go down the route of buying a DVD recorder with a hard drive. You'll need one with an S-Video input. And many now step this up to certainly 720P for a high def, output (HDMI) Newer ones will probably step up to 1080p.
The flexibility of a DVD recorder with a HDD will allow you to record as many takes as you want, edit and title them, also write to DVD if desired.
I'd go for the machine with the largest possible hard drive I could afford, these high def data files are usually pretty huge. Especially when uncompressed.
Worth checking for one that also has a USB port for quick file transfers.
Finally, if funds are available, then a Blue Ray recorder with a Hard Drive. Again make sure you have a S-Video input, USB port and the output ports you need. Blue ray will by definition mean you're using high def. quality video.
Oh ......... check that the box that you do buy also has a suitable connection for the monitor you're using.
Here's a url for the wikipedia website on the subject:-
http://en.wikipedia.org/wiki/High-definition_television
Towards the bottom, there are links to Extra High def 1440p and Ultra high def 4320p
I would imagine we're stepping into the realms of financial fantasy with this stuff, but its worth a read.
5/31/2011 3:47:13 PM • Leadtek WinFast... • Answered on May 31, 2011
Can i use microphon on
No , you cannot use microphone on WinFast PVR2000 . The two audio jack is for audio input ( L & R).
Thanks
Please rate me if you got a satisfied answer
3/20/2011 11:28:35 AM • Leadtek WinFast... • Answered on Mar 20, 2011
Audio
if you are having trouble with the sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
2/5/2011 3:49:23 PM • Leadtek WinFast... • Answered on Feb 05, 2011
0answers
No sound from WinFast PVR2 tuner card
i looked at my windows xp winfast and i discovered that the audio was working only with the realtek hd audio
now the link is here and u can chose the driver:D:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
6/20/2010 6:01:18 PM • Leadtek WinFast... • Answered on Jun 20, 2010
Windows 7 64bit driver
which driver you need write it details ( audio, video, graphic, lan, wlan, etc.)
4/29/2010 12:47:43 PM • Leadtek WinFast... • Answered on Apr 29, 2010
I can't reinstall divre for tuner pc card
first install the software/driver. make not to connect the tuner card.
next, insert the card then let it detect by itself. if it doesn't work then ask for a new driver. also be aware of your driver is match with your operating system.
4/10/2010 9:47:47 AM • Leadtek WinFast... • Answered on Apr 10, 2010
When I try to access PVR2 on my computer it tells
Ok that simply means that the DirectX "Graph" or the way the filters are loaded and used, via DirectX are not being loaded or found, for many reasons. This could be a Filter not present, or a "Pin" cannot be found. You need to have all Filters installed and registered. You need the the MPEG 4 and MPEG2 Filters installed and registered. CoreAVC is real good. You should load the software that came with your card and install that and the driver. then install all CODECS and Filters I wonder if a simple re-registering all your filters will not fix it. try that. Also try installing WinDVD, that will install CODECs that may be missing, you need to get HDTV codecs that will help,also reinstall the software and drivers that came with the card.
www.free-codecs.com › ToolsDigital Radio - TV -
http://www.free-codecs.com/Software/Digital_TV.htm
At the link above, download the Amcap software it will allow you to see and use the card.
http://en.wikipedia.org/wiki/DirectShow
link above explains about graphs
3/30/2010 1:11:42 AM • Leadtek WinFast... • Answered on Mar 30, 2010
No sound
It uses your computer's standard sound card. You should plug the audio output from the TV card into the Line In on your computer's sound hardware.
3/10/2009 7:45:27 PM • Leadtek WinFast... • Answered on Mar 10, 2009
Using TV card on PC video perfect no audio
SOme PVR cards need a small cable from PVR card to the Sound card input to play sound via the sound card.
1/16/2009 6:05:40 PM • Leadtek WinFast... • Answered on Jan 16, 2009
TV Tuner viewing
When running TV, click anywhere on it's screen, this will produce a 'drop-down window' within screen.
You can select the "Always on TOP" option.
You can also grab BORDER, with mouse, to resize it to whatever size you want.
9/9/2008 3:04:23 PM • Leadtek WinFast... • Answered on Sep 09, 2008
Audio only capturing through one speaker
Check the mixer and make sure that the recording source used for capturing is enabled and that the channel is set for stereo by making sure that the balance is in the middle.
8/4/2008 5:37:31 AM • Leadtek WinFast... • Answered on Aug 04, 2008
Leadtek WinFast PVR2000 Video Capture Logo
Popular Tags
31 questions posted
Top Leadtek Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Leadtek Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Winfast Leadtek
  • Winfast Leadtek
Most Popular Question
im doctor doing cardiac ultrasound
  • Televison & Video
