20 Most Recent Sharp 13VT-K150 13 in. Combo Questions & Answers
For these tvs you have to unplug them for three hours to reset them. When you are able to access the menu if the remote control is not allowing you to move up and down left and right usually channel up is up channel down is down volume - is left and volume + is right. If worse comes to worse you can get the original remote from Sharp for $42.50 +tax and shipping by calling 1.877.674.2832 or from replacementremotes.com for $39.65 at 336-377-2220. The remote can always be returned if having it does not fix your problem.
Sharp 13VT-K150... | Answered on May 05, 2010
dont have original remote anymore what do I do
Sharp 13VT-K150... | Answered on Aug 31, 2009
go into set up and go to diagnostics
Sharp Televison... | Answered 24 hours ago
Ask Sharp at: http://www.sharpusa.com/CustomerSupport/ContactUs.aspx
Sharp Televison... | Answered on Jan 13, 2020
please remove. Not a question!
Sharp Televison... | Answered on Jan 12, 2020
Maybe its anothr issue...chec utube or repairbooks in library
Sharp Televison... | Answered on Jan 10, 2020
the only proper way is to remove the rear cover and resolder the connector back on the circuit board my advise is to get a tv engineer to fix it for you or you can use a differant input ie.scart or hdmi etc.using a set top box or a dvd recorder or similar using the tuner within that hope that helps you
go into set up and change input or source then see if audio is ok and speakers are on
Sharp Televison... | Answered on Jan 06, 2020
TRY THIS- press menu button and put the numbers 1147 in..A NEW BOX WILL POP UP and in the box that comes up PRESS THE FIRST OPTION it was the top one on my sharp tv...the tv will then go off ...using your remote turn the TV back on...you will then go through the set up as you did when it was new...SORTED NO MORE YELLOW K, Just done this myself after advice on the phone from Tesco tech support
Sharp Televison... | Answered on Jan 03, 2020
Sharp 13VT-K150 13 in. Combo Logo
8 questions posted
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
resetting lock accessing menu universal
  • Televison & Video
