20 Most Recent Dyson DC25 Animal Bagless Upright Vacuum Questions & Answers
4answers
Dyson dc25 power switch will not stay on
I called Dyson because I had a similar problem. When I pushed the red button down on my dc25, but it would not stay down. The vacuum would turn on when the button was pushed down, but of course when I let go of it the vacuum would shut off. The helpful telephone tech. Recognized the symptom right away and told me to push down on the button fully and let It flick up like a lighter. I about fell off my chair when that worked right away! Anyways for what it's worth, she said sometimes the mechanism in the buttons gets consnarlitated (my tern, not hers!) and this resets the spring.
10/23/2022 2:56:44 AM • Dyson DC25... • Answered on Oct 23, 2022
Dyson dc25 animal - head won't stay on the floor - doesn't seem to be rotating correctly
I am having the same issue in 2022. Dyson says I have to buy a new machine. EVERYTHING else works perfectly and I can vacuum the floors IF I hold it almost upright. Who can clean a 2,000 square foot house with hardwood, tile and carpet like that?? Not me! I cannot believe this can't be fixed in this day and age. Am I to take it to the recycle center? What about the perfectly good 8 attachments I have for it? If I get a new one, it will come with 4 or 6 of the same attachments. This is a total waste of money in this day and age -- to say nothing of disposing it in the landfill!!! I AM NOT HAPPY with Dyson at the moment.
6/21/2022 8:15:36 PM • Dyson DC25... • Answered on Jun 21, 2022
Ball filter is popping up, stopping ball rotating and ball area is getting hot
Hi there,I'm sorry to hear you're having difficulties with your DC25 Animal. If the filter inside the Ball will not stay in place during use, please make sure that when you refit it, it locks into place with an audible 'click'. I can confirm it's normal for your Dyson to become warm during use, but if you're concerned that it seems excessively hot, I'd encourage you to get in touch with us directly so we can help. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).Best wishes,JackDyson Online Customer Supporthttp://www.dyson.com
9/13/2019 3:16:54 PM • Dyson DC25... • Answered on Sep 13, 2019
7answers
Inner ball filter keeps popping
Air filter is not getting air flow.air must pass thru filter or it will pop off.I placed filter against exhaust end of shop-vac ( NOT SUCTION END) untill I got air coming out.
11/10/2018 11:50:57 AM • Dyson DC25... • Answered on Nov 10, 2018
My Dyson DC-25 Animal's rotor head lifts off the ground when I rotate the upright handle to the normal working position. The red and gray bars are unlocked.
There is probably some dirt or debris in the moving parts causing a restriction. The parts may have some wear or abrasion too.
11/3/2017 1:21:15 AM • Dyson DC25... • Answered on Nov 03, 2017
I can not push my Dyson animal vacuum as the ball is stuck what is blocking it?
Most times it is the hepa filter in the ball . If it has not been change the air on the exhaust pushes it away or off the holder yake it out and put cap back on see if it pushes then. Then replace the filter before using it Dyson DC25 Filter Kit Includes 1 919171 02 Washable Pre Motor Filter amp 1...
10/27/2017 2:08:28 PM • Dyson DC25... • Answered on Oct 27, 2017
I have the animal dyson and the ball is sticking and getting stuck, making it very hard to push. Help please
Make sure the screws holding the two halves of ball together are tight
3/19/2017 11:20:45 PM • Dyson DC25... • Answered on Mar 19, 2017
Roller bar will not spin on dc25 animal
If the brush bar motor is running try putting on a new belt. If the motor is not running it may be the main switch, the switch that activates when you recline the handle, the motor itself or a loose wire or connector somewhere. Check the connection between the vacuum and the power head. If power isn't transferred properly the motor will not run. You have to closely check all these areas to find the problem.
3/10/2017 5:33:46 AM • Dyson DC25... • Answered on Mar 10, 2017
How to remove ball from Dyson dc 25 Animal ?
Remove the torx screws that hold the two halves of the ball shell assembly together, then the ball halves can be separated and removed from the vacuum. Take note of how they come apart and how they line up su you can reassemble them properly.
2/5/2017 7:06:49 PM • Dyson DC25... • Answered on Feb 05, 2017
The Dyson Vacuum Animal DC25 stopped running and will not turn on. Are there fuses some place that can be replaced or other ideas?
First check the cord for proper voltage, if that's good check the switch. If still good, cjpheck cord from switch to motor, if all is good check the motor.
1/16/2017 2:11:24 AM • Dyson DC25... • Answered on Jan 16, 2017
The handle for my dc25 animal wand has come apart leaving a clear plastic ring, a clear plastic bracket and a spring - how do I put them together?
Check out dyson's support page. http://www.dyson.com/support.aspx
8/6/2016 7:30:12 PM • Dyson DC25... • Answered on Aug 06, 2016
When you are running the vacuum does the dirt that is inside the bagless container circulate?
Empty the vacuum dirt container and clean the filter.
4/19/2016 4:26:26 PM • Dyson DC25... • Answered on Apr 19, 2016
2answers
Vacuum will be working and then it cuts out, like it loses power. Plug it into a different outlet and it starts working again.
Your vacuum has a thermal reset built into the motor. If it is getting to hot it will shut off and won't turn on until it cools down. This is a sign of a clog somewhere or the filters need to be replaced. If you are getting dust building up on the vacuum that is an indicator the filters may need replaced.
4/17/2016 12:00:13 PM • Dyson DC25... • Answered on Apr 17, 2016
How do i release the handle on my dc25 dyson vacuum
Hi Dan, it's Jack at Dyson. I'm sorry to hear you're having difficulty releasing your DC25's wand, but this is likely to be simple to resolve. It probably just means that the hose was twisted around when you last replaced the wand on the machine - allowing the hose to unwind will free up the wand. Just follow these steps: I'm confident this will help, but if you'd like any further guidance after you've given this a try, you can reach our experts directly by calling the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
3/1/2016 10:30:10 AM • Dyson DC25... • Answered on Mar 01, 2016
When vacuum is in the upright position and i pull back on the handle the front roller bar stays on the floor.
Hi Ronald, it's Allan at Dyson. This might be an easy fix or you might need an engineer to visit you and make a repair. Please have a look at the video first. If you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand. Many thanks, Allan
1/21/2016 2:35:53 PM • Dyson DC25... • Answered on Jan 21, 2016
Ball seems to be stuck
Check w/YouTube w/ model number for info. Good luck!!
8/9/2015 4:22:21 PM • Dyson DC25... • Answered on Aug 09, 2015
Why does the filter in the ball keep popping out?
Hi Mrs Killick, it's Jack at Dyson. To resolve this, try removing and replacing the post-filter, as shown in our filter wash video guide below: When replacing the filter, make sure you push it firmly into place, until you hear a click from the red locking catch. If you continue to have difficulties after you've given this a try, please contact the Dyson Customer Helpline directly as I'm confident we can help you with this. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
7/30/2015 2:39:38 PM • Dyson DC25... • Answered on Jul 30, 2015
Dyson DC25 Animal Bagless Upright Vacuum Logo
210 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
dyson dc25 power switch will not stay
  • Vacuums
