20 Most Recent Alpine Air XL-15 Air Purifier Questions & Answers
I have an Alpine ZL-3
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
9/5/2022 2:16:27 PM • Alpine Air XL-15... • Answered on Sep 05, 2022
Need schematic for Alpine xl-15 air cleaner
clean the plates first ,
10/26/2021 4:38:54 PM • Alpine Air XL-15... • Answered on Oct 26, 2021
2answers
Air Purification Unit Model ALP-615
Moist air reduces the efficiency of ozone production for this unit. I am not sure what the water thing is about.
Did you try cleaning the glass plate or ceramic plate ozone producing unit with soap free ammonia? Also did you try using a pencil eraser on the contact points on the glass plate? I think the ammonia cleaning and contact points on the glass plate should be your first option. Check your maintenance on the units manual.
Try the manufacturers website for their trouble shooting guide...walks you through most problems and how to fix them.
10/5/2021 10:09:58 AM • Alpine Air XL-15... • Answered on Oct 05, 2021
How often does the manual suggest changing the glass plates?
Clean the filter and dust out the inside from time to time. If the plates are slightly chipped, it mon't matter. Mine has been in constant use for about 3 years. That's all I do and it works just fine.
10/5/2021 9:20:18 AM • Alpine Air XL-15... • Answered on Oct 05, 2021
2answers
Why would new fan motor blow the air backwards
Lmfao at Ken, dude this is a single phase 120 vac motor. You can close your eyes and pick one there is no switching of wires to the motor. YOur hot can go to which ever and your neutral can go to which ever. DOES NOT MATTER :-P don’t reply unless you know blow horn. But just a heads up you can Reverse rotation very easy...
3/20/2018 11:07:36 PM • Alpine Air XL-15... • Answered on Mar 20, 2018
0answers
2answers
Where can I find a ozone control for the XL-15?
i contacted Living air about this and they replied back stating that you can not buy this that you have to send the unit in for repair. Sounds like a rip-off to have to pay to ship it off just to have someone to plug in a new module that takes all but 1 minute.
10/4/2016 6:03:41 PM • Alpine Air XL-15... • Answered on Oct 04, 2016
We are using a living
I would doubt that high ozone levels are causeing your problems. It is possible if your house is not properly ventilated for ozone to be hazardous so I would recommend that you cut the time that you are using your air purifier in half and for the next 2-3 months I would change furnace filters on a weekly basis.Also clean all carpets and drapes to remove all tobaco residue. I hope this helps you and that you all start feeling better.Thank you.
5/28/2016 8:40:37 AM • Alpine Air XL-15... • Answered on May 28, 2016
My unit has no ozone smell after close inspection I noticed a burnt resistor on the power supply board, where can I get a schematic for correct resistor size?
The colour rings on the resistor tell the ratings of it. Should be able to google a resistor chart.
5/26/2016 5:19:02 AM • Alpine Air XL-15... • Answered on May 26, 2016
What does E1 mean on my green air purifier
Probably ozone plate needs to be cleaned or replaced.
6/12/2015 1:49:41 PM • Alpine Air XL-15... • Answered on Jun 12, 2015
3answers
XL15
The ozone plates need to be cleaned monthly to work effectively. You can get an owner's manual for free from the manufacturer's website, it's at:
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pdf
The manual has a description of the type and frequency of cleaning of various parts of your air purifier. Hope this helps!
4/2/2015 5:05:15 AM • Alpine Air XL-15... • Answered on Apr 02, 2015
I have an alpine living air model xl15 it is mounted on my air return on my furnace not sure how it works it has a manual and a automatic switch what setting should i put it on?
You mean an auto and normal setting. I don't have a manual but I always use the normal setting. I don't remember what the auto setting does.
4/10/2014 2:00:00 AM • Alpine Air XL-15... • Answered on Apr 10, 2014
O3 is not working
You need to either clean the plates w/ a 50-50 solution of ammonia & water or you need to replace the plates because they're burned out. I can help w/ both.
4/10/2014 1:38:45 AM • Alpine Air XL-15... • Answered on Apr 10, 2014
Alpine Air XL-15 Air Purifier Logo
157 questions posted
Top Alpine Air Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Air Air Purifiers
Most Popular Question
alpine xl 15
  • Air Purifiers
