20 Most Recent
Lite On SOHR-5238S CD-RW Burner Questions & Answers
How could i make my
Click start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer:
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone:. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
7/14/2011 6:57:57 PM •
Lite On...
Answered
on Jul 14, 2011
How can i make my
Hi Justin
If it's a CD-RW burner then you can't burn any DVDs in it. You need to get a DVD burner instead - they are very cheap now.
7/14/2011 6:16:32 PM •
Lite On...
Answered
on Jul 14, 2011
I need help finding out
sounds like a faulty electrical connection check all connections that attach PSU to your burner or go into administrative tools,computer management, device manager if yellow? uninstall or roll back then once you uninstall diconect from PSU then re attach re-install
7/27/2010 10:51:21 PM •
Lite On...
Answered
on Jul 27, 2010
Lightscribe
They will have the lightscribe logo on them if they are compatible. They need to have a special ink embedded on the lable side.
9/19/2009 9:02:16 PM •
Lite On...
Answered
on Sep 19, 2009
Computers
most backup software can do this.
If you have about an hour to wait, you can use the shareware version of winrar to create a multi-volume .rar compressed file. You can set the target file size (in this case 700mb) and it will split it up automatically.
Note that when you restore the data in the future you would have to copy the data all into a single folder before restoring it.
Another option you have is to buy an aftermarket backup/archiving program. nearly every one except the free one with windows will let you burn to cd/dvd.
8/13/2008 5:46:44 AM •
Lite On...
Answered
on Aug 13, 2008
Lightscribe enable
afraid it doesnt have lightscribe built in.
All the best
John
7/30/2008 1:25:42 PM •
Lite On...
Answered
on Jul 30, 2008
Pc does not recognize when i insert a cd
with ur cd ROM u will get a cd which contains driver if ur cd ROM U NEED TO INSTALL IT AND ITS AUTO RUN PROCESS SO INSTALL IT AND REBOOT THE PC>rate me SOLVED IF ITS HELP FULL
10/30/2007 4:01:14 PM •
Lite On...
Answered
on Oct 30, 2007
I want to move old HDD drive from broken down LiteOn 5045A DVD recorder to replacement DVD recorder machine...
cart before horse.!WELL BAD NEWS (TOPIC) HDD.the drive is 21 years old tech. 2001it is not any kind of modern standard HDDit is PATA(IDE) NOT MODERN SATA (SERIAL ATA)SO ONLY RELIC OLD DRIVES CAN WORK HERE.or run old 20+ hdd tests that take a week to finish(now you see why SATA was born, PATA stinks)and worst is the DVD burner is not a desktop or laptop standard drive and worse yet PATA againthe old DVD drive, replacement can be hard.lite-on does not support old things, gee most makers do not after 17 year old.also read here, and see how spare parts actually workin this old burner systemhttps://forum.videohelp.com/threads/325208-Liteon-LVW-5045-replace-DVD-drive-project-startedwhat your are attempting is not easythe huge problem is fireware in the devicemany not allow larger HDD over 160GB new.or may not allow all makers of the drive to work at all.is not that DVD DRIVE, PATA DRIVE, NOW 100% OBSOLETETHE SAME FIRMWARE RESTRICTIONS (NOT DOCUMENTED ON EARTH i MIGHT ADD) WILL NOT ALLOW SOME DVD DRIVES BY OTHER MAKES.... LOOKING NOW AT OTHER WORKING ON THIS OLD BEAST WHAT DO I SEE IN their nice PHOTOSL (tech eyes win)the hdd iS NOT SATA IT IS 20 YEAR OLD PATA(IDE) JUNK.FINDING GOOD USED PATA DRIVES IS HARD..NEW ONES ARE SOLD AT SCAPLERS PRICES, (AS expected)the DVD drive is clearly custom made by SONy for Liteon..HERE IS DVD PROOF OF NON STANDARD DRIVE(FIT)
5/15/2022 11:40:43 AM •
Lite On...
Answered
on May 15, 2022
