20 Most Recent Toshiba Satellite C655-S5082 Laptop Questions & Answers
I bought a brand new Toshiba Satellite C655, I
Ran into this 1 before a few times on the 600 series Cs, once was a driver issue from a virus left unrepaired and the second time was a bios error which required me to obtain the bios update and reflash the bios, not an easy project at all, but watch the youtube how to videos and im sure you could handle it :).
11/8/2017 1:53:09 PM • Toshiba... • Answered on Nov 08, 2017
The charger for the the
Using a volt meter check the output of your adapter. If not within specs it is no good.
8/29/2017 1:10:35 PM • Toshiba... • Answered on Aug 29, 2017
I have a toshiba satellite C655
some laptops will run with out battery and at some point replace it.
4/12/2015 2:20:59 PM • Toshiba... • Answered on Apr 12, 2015
Lg pairing
What lg device is it that you're trying to pair with the laptop?
8/4/2014 2:31:04 AM • Toshiba... • Answered on Aug 04, 2014
My touch pad can control but cant select and the left click does not work please help me because i need it this morning to do a presentation
Check that your drivers for your touchpad aren't missing/corrupted and update them if necessary under the Devices menu. If that doesn't work, back up your work and do a system restore. If -that- doesn't work, you need to call in for repair service and I'd suggest getting a USB mouse in the meantime.
1/20/2014 12:22:54 PM • Toshiba... • Answered on Jan 20, 2014
Can you install a printer to satellite C655
Of course, if you have the software or are able to find the correct drivers that are compatible with your Operating System. You need touse a USB cable, or an Ethernet cable. If it has wireless communication capabilities then you can also connect it to the computer through the wireless.
10/20/2013 2:46:36 AM • Toshiba... • Answered on Oct 20, 2013
0answers
AC Charger wont stay in the laptop
Is there a bent pin in the dc jack on the computer? Did you get the right charger? Is the DC jack on the computer loose?
6/6/2013 5:38:43 AM • Toshiba... • Answered on Jun 06, 2013
How can i enable my wireless
Make sure the wireless driver is installed. You can download the wireless and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
5/16/2013 1:20:43 PM • Toshiba... • Answered on May 16, 2013
Driver
First, you have to turn on the wireless switch - Try to power on the wireless by pressing FN+F8 together2.If its already turned on but disabled than you have to enable it:- Second, in the task bar, click on the local area connection icon ==> wireless network connection ==>enable if you do not know the local area connection icon, try to pass your mouse over icons in the task bar, and read the labelsORor go to start>>control panel>network connection>right click on wireless network connection and left click on enable.I hope this will be helpful for you. please mark the solution if it was helpful. also let me know if still issue persist.Regards,sunil kumar
5/16/2013 11:06:52 AM • Toshiba... • Answered on May 16, 2013
Toshiba locked
It isn't the government. It is a SCAM!Even if you pay the extortion money, nothing changes.I received this information from another expert, in an alike problem.The solution is to remove the internet access to the computer.Then put the Restoration disk in your optical drive. (CD/DVD drive)When asked choose Full Install. Destructive Installation.The computer will go back to day 1 from the factory.ALL personal information will be lost.ALL installed, or downloaded programs, will be lost.Regards,joecoolvette
5/13/2013 8:27:59 AM • Toshiba... • Answered on May 13, 2013
After replacing hard drive still getting check cable connection no bootable device
you may need to enter the bios setup and change the setup for the hard drive from sata to ide connection then it should recognize the new hard drive then simply install windows to your new h/d
12/19/2012 3:30:32 AM • Toshiba... • Answered on Dec 19, 2012
How to hook up my toshiba c655 to tv and have audio
If you have HDMI out on your laptop, it should send the sound and picture to your TV (make sure appropriate drivers are installed). If you only have VGA out, then it will not send sound. Tthe only other option is if your TV has Audio IN (either 3.5mm headphone jack, or RCA Left/Right), then you could connect the headphone jack of your laptop to the TV that way.
6/19/2012 9:29:07 PM • Toshiba... • Answered on Jun 19, 2012
2answers
I think my backlight went out o0n my computer how
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
8/16/2011 12:28:12 PM • Toshiba... • Answered on Aug 16, 2011
I have a Toshiba Satelite
Look at the transformer/power pack and somewhere it will tell you the volts, amps and watts. My dell 15.4" PC takes a "65 watt" power pack. Get an inverter thet is at least twice as big in my opinion.
A standard size is 300 watts. I would be sure it has at least one USB charger as well. They start at about $25.00 and go up.
Here are three at random.
http://cgi.ebay.com/300W-CAR-POWER-CHARGER-INVERTER-CONVERTER-USB-PORT-/270677912841?pt=LH_DefaultDomain_0&hash=item3f05a92d09
http://www.amazon.com/Jensen-JP30-Watt-Power-Inverter/dp/B00005LACE/ref=sr_1_1?ie=UTF8&qid=1311814985&sr=8-1
http://www.amazon.com/dp/B004NZE9AK/ref=asc_df_B004NZE9AK1636786?smid=AWZ3LXPHZK09&tag=nextagusmp0350481-20&linkCode=asn&creative=395105&creativeASIN=B004NZE9AK
Have a safe trip!
7/28/2011 1:07:19 AM • Toshiba... • Answered on Jul 28, 2011
2answers
The USB ports have stopped
Sounds like you have a BIOS problem, it needs to be flashed to the latest BIOS version, you have to check your manufacturer's support website and download the correct one for your specific hardware and model.
Check here, http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2759785&rpn=PSC08U&modelFilter=C655-S5082&selCategory=2756709&selFamily=1073768663
5/12/2011 11:09:19 PM • Toshiba... • Answered on May 12, 2011
Replaced inverter cause screen went black but
Could be also a defective LCD backlight lamp.
Please refer to the following article for some tips on diagnosing & fixing this issue:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
4/18/2011 7:43:55 AM • Toshiba... • Answered on Apr 18, 2011
I was letting my son
Most of the time, the bios password can not be reset unless you pull out the CMOS battery and do a reset switch.
Shortly, you will need to bring it to someone if you aren't comfortable opening the laptop. If you are comfortable, open it up, remove all the screws and pieces and then when you get to the motherboard (big green thing with a bunch of electronic looking things soldered to it), find a battery that looks like a watch battery. Carefully remove it and let it sit for at least 24 hours (with no other power sources connected) and that should clear it out.
3/23/2011 2:57:27 PM • Toshiba... • Answered on Mar 23, 2011
Toshiba Satellite C655-S5082 Laptop Logo
Popular Tags
30 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba locked
  • Computers & Internet
