20 Most Recent
NEC PlasmaSync 42VP4D 42 in. HD-Ready Television Questions & Answers
NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
Metade tela preta metade branca
Hello
From your description, I can't understand the problem of your TV well. "Half white half black screen with video signals"; you describes what? Please give me more details about the fault, as clear as you can, so that I can help you. Send these details to me by Fixya. OK.
How do I turn on the plasma monitor without a
No,a universal remote is cheaper,but those codes they give on the owner manual for ur tv model might work or not at all.Try website like Remotes.com to buy an original remote or very close to the original remote.
Does anyone have the voltage specs on a PNT-426
I have a PX-42VM5A and my Power supply is a PNT-426 (by Sanken Electric Co. LDT). Here are my specs: INPUT: AC 100-240V; OUTPUT: (there are nine outputs) +170v 1.6A; +60v 1.6A; +5v 4.0A; +2.5v 1.9A; +3.5v 1.9A; +7v 1.0A; +12v 0.5A; +12 v 1.9A and +6v 1.2A
Plasma 42 inch nec
the problem is most likely that there is no signal on the cable you are using.
check with a regular tv to make sure you have a signal.
Thanks
guy9
This one might be for you
Thanks for the pointer. It took a while to findthe original question which was only refering to a bad power supply. I'll look into this further. Thanks for the pointer.
Dan
42VP4D
Try to call the Company Tech Support and ask the part. Thats the perfect place to get your perfect parts. Or get your part number and search the web for inexpensive one but make sure you get the right one. Good luck
