20 Most Recent
RCA Lyra RD2762 MP3 Player Questions & Answers
Mp3 player dies after one or two songs even fully
If even affer charging for a long time the battery is draining off you will need to change the battery. Remove cover carefully test and confirm before you replace. attempt only if familiar and to do it carefully.Good day
RCA Lyra If I can get it to turn on it says file
Connect you MP3 player to your Computer/Laptop and see if you have any .MP3 or .WMA music files: if you have none, or the files format/encoding are not compatible, the player will say 'file not found' !
In any case, try resetting your MP3 player (look in your manual, but it is usually hold the software controlled on/off button in the OFF position for 15+ seconds before releasing it to the neutral position). As a last resource, also reformat your 'flash' drive in your MP3 player using Windows format function or a Flash drive utility.
RCA LYRA RD2762B (4 GB ) MP3 Player
I had same issue and found a law office that filed a class action against RCA/Thompson. Here is the result:
Thank you for contacting David P. Meyer & Associates Co., LPA about the action our law firm filed against Thomson regarding RCA mp3 players. The matter was settled on behalf of the individual Plaintiff and the lawsuit was dismissed on October 10, 2007.
If you have a hard disk drive player that is experiencing a file error corrupt or similar error and you meet certain requirements, you may be entitled to a replacement unit at no cost to you. You must contact Thomson at 1-800-587-5518 no later than December 31, 2007.
Best Regards,
Shelly Coffman
Claims Investigator
1320 Dublin Road, Suite 100
Columbus, Ohio 43215
Direct Dial: 614-384-7030
Toll Free: 1-866-827-6537
Fax: (614) 224-6066
E-Mail: [email protected]
Website: www.dmlaws.com
HELLP
You can send it to the RCA Company, look in the phonebook, or use the "Repair Service" bar which is located on this website.
