20 Most Recent RCA RC5215P DVD Player Questions & Answers
Wrong Format
I have a feeling this might be a region issue. If your DVD is the correct region for your country (check it against this list) 1: United States, United States Territories, Caribbean, and Canada 2: Europe (including British and French territories), Japan, South Africa, and the Middle East 3: Southeast Asia 4: Latin America, Australia, and New Zealand 5: Russia/Eastern Europe, Central and South Asia, and Africa (except Egypt, South Africa, Swaziland, and Lesotho) 6: China (7: unused) 8: airlines/cruise ships then your DVD-player might not be set up properly or may be faulty. Have a look at the settings and make sure the correct region code is set up in your player. If you find a "0" as the region code it means your player can play all regions.
1/21/2018 10:49:49 PM • RCA RC5215P DVD... • Answered on Jan 21, 2018
Need remote code fir Direct TV remote RC32
Contacted a Directv Tech to get a rc64 remote and use the 10835 code to get the TV to turn on/off and volume up/down to work!
9/22/2012 8:06:39 AM • RCA RC5215P DVD... • Answered on Sep 22, 2012
Need factory parental code for rca dvd player RC5215P
First of all, thank you very much for choosing FIXYA today for your online technical support needs.See page 64 of the User's Manual for detailed instructions on how to reset the LOCK feature if you forget the password.Basically you just press and hold the STOP button on the front of the machine as well as the STOP button on the remote control and hold them both down at the same time for about 3 seconds. Here is a direct link to the ONLINE USER'S MANUAL for that model:http://support.radioshack.com/support_video/doc66/66049.pdf To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual. You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer. I truly hope that was helpful to you. Good luck and take care. Joe.
1/20/2012 1:21:10 AM • RCA RC5215P DVD... • Answered on Jan 20, 2012
Play dvd has no color
This is often the problem when the output is set incorrectly. i.e. you are using component cables and the output of the unit is set to video or such, try looking in set up on the menu screen and see id you can change the output.
The other time I have had this happen is when the RGB plugs were in the wrong hole.
Hope this helps you, Cheers, Rob
12/28/2008 8:06:30 AM • RCA RC5215P DVD... • Answered on Dec 28, 2008
2answers
Disc Incompatible
my friend u just clean the lense by cotton tips without applaying any liquid or spray air which is available in pressurised containers.I have the same DVD player with missing of IC no:104 in signal board which is placed under the lense mechanism,please I like to request u to send the IC number on following ID [email protected] or [email protected]
8/1/2008 2:43:33 AM • RCA RC5215P DVD... • Answered on Aug 01, 2008
Three Problems, Please.
Dear brother Iam also a Technician like u I have also the same dvd player with me with missing IC104 in signal board under the lense mechanism,How ever the problem which u explaind in ur question I think it is problem from the lense,becouse I got so many DVD players (not mentioned player)for the explained symptoms and most of that when I change lense become good.
Dear brother I have a request to that to mail me the IC 104 number in follwing address.noushadkaruvally at yahoo.com
2/5/2008 9:44:50 PM • RCA RC5215P DVD... • Answered on Feb 05, 2008
RCA RC5215P DVD Player only plays in black & white
Dear brother at first u insert a original copy righted disk and check .And there is an option for swithing in menu for PAL and NTSC.And also please check ur TV is supported NTSC3.15 colour system,If not check ur player in a multi system TV.
Dear brother if u r a technician please can u mail me the IC number of IC104 in signal board under the lense mechanism in the same RCA RC5215P DVD player,becouse I have missed this IC from my player
2/5/2008 9:32:17 PM • RCA RC5215P DVD... • Answered on Feb 05, 2008
2answers
Finding lense
to find the laser remove the cover, with the dvd tray open. now you may have to remove the piece of plastic that covers the dvd when it plays. below that is your laser. the lense itself is about the size of a pencle & clear plastic. cleaniong the laser with a swab is a lot better that relying on those lens cleaning kit you can get. as for the ic i don't know what you mean? good luck.
2/2/2007 8:51:50 PM • RCA RC5215P DVD... • Answered on Feb 02, 2007
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
I dropped my RCA remote control, how can I reestablish connection with Magnovox tv?
Check that the batteries haven't become disconnected. Do the Smartphone camera test to see if it is transmitting a signal. If it isn't, buy a remotes specially made for the Magnavox rather than an RCA Universal. Google Magnavox (model) remote control replacement. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/30/2023 4:26:09 PM • RCA Televison &... • Answered on Nov 30, 2023
My old Panasonic TV set has no video RCA slot. Only audio R and L slot available.
tv is not a smart tv, may have to replace it.
11/27/2023 3:30:48 PM • RCA Televison &... • Answered on Nov 27, 2023
RCA RC5215P DVD Player Logo
19 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
need factory parental code rca dvd
  • Televison & Video
