20 Most Recent RCA DRC8300N DVD Recorder/VCR Questions & Answers
2answers
Dvd movies plays on computer but on in dvd player
Try to make a backup copy of your DVD there is so many program free on internet thaat you could get good luck!
3/14/2020 5:53:50 AM • RCA DRC8300N DVD... • Answered on Mar 14, 2020
16answers
RCA DRC8320N Appears Dead
For units with no functions, appears dead, power supply gets a leaky capacitor in power supply. Designator #C232 on pc board. It is a 1000uF 16volt capacitor that needs to be replaced.
12/30/2016 2:15:41 PM • RCA DRC8300N DVD... • Answered on Dec 30, 2016
3answers
Dvd sound isn't working
In addition to the suggestion which I fully concur with, there is one small thing I would add. Kari you may not be aware that there is often an "internal setting" in the dvd player for its output volume. Sometimes the setting is inadvertently changed to a permanently "muted" or silent mode so that no audio can be heard. This internal setting is usually accessed by pressing the "Setup" button on your remote control and browsing through the main menus to the "Audio" or "Sound Setting" submenu. Once there you will see if the settings are correct in order to HEAR AUDIO (sound that is). Be sure to turn the "MUTE" to "off" and set the output volume to about 3/4 high setting. Then get out of setup mode and play your dvd. My point is this...on some "kareoke" feature units I have found many people mistake the front manual volume control for a DVD audio output level control when playing dvd's. This is not the case..the output volume settings are "internal" and accessible through the remote control only. Hope this helps Kari !- hattonhall
7/15/2016 5:22:13 PM • RCA DRC8300N DVD... • Answered on Jul 15, 2016
Our system says it does not recognize any recordable dvd we've tried. Suggestions?
First...try to unplug the unit...and re-plug the unit a few time..that May reset the Microcontroller inside the recorder. Second..put a DVD movie inside and see if the recorder respond properly, if yes...play the DVD.
If that not work...it could be the Microcontroller and program maybe faulty...my guess
3/10/2015 2:08:46 AM • RCA DRC8300N DVD... • Answered on Mar 10, 2015
Rca drc 8320n lock on pls wait no front butons recognize
I have the same problem too. And it swallowed my tape. I disassemble, took the tape assembly out and get my tape by putting 9 V to the motor ( the small dc motor ) so I can get my tape. I did plug in the unit without the tape assembly, still say "Please Wait"...Therefore it is maybe the microcontroler not following the program and may possible need to be reset, with the power on. So I will need the chip location, the pin out of the microcontroller, and solder a push button at the reset pin of the MCU and see what happen.
2/16/2015 9:20:36 PM • RCA DRC8300N DVD... • Answered on Feb 16, 2015
Acoustic solution 263 not loading
www.rca.com/support/product-specific-support
7/6/2014 2:52:15 AM • RCA DRC8300N DVD... • Answered on Jul 06, 2014
Vcr tape gets hung when insert to play;can't get the tape out out
Make sure the tape hasn't wound around the drum. If it has then press the eject button several times. Check the loader motor to see if the belt is slipping or has fallen off.
1/29/2014 12:29:49 AM • RCA DRC8300N DVD... • Answered on Jan 29, 2014
The player does play the
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
9/3/2012 8:37:49 AM • RCA DRC8300N DVD... • Answered on Sep 03, 2012
Rca8320 powers on vhs plays and record.dvd player not working
HelloCheck whether the DVD spins inside the mechanism after load. If it does not spins, repalce sled motor. if it spins and still not read any discs, the laser pickup unit is faulty, should be replaced with same type and number.
2/29/2012 3:08:10 PM • RCA DRC8300N DVD... • Answered on Feb 29, 2012
2answers
Pictue but no audio on VHS playback..VHS record to DVD visual/no
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
12/16/2011 2:18:41 PM • RCA DRC8300N DVD... • Answered on Dec 16, 2011
It will not play the tape or eject the tape. The
RAV= Rear Audio/Video jacks, the RCA type jacks, FAV means the front jacks,Don't know what the others mean. Hope this helps some, Wally
11/5/2011 4:31:57 PM • RCA DRC8300N DVD... • Answered on Nov 05, 2011
RCA DRC8300N DVD Recorder/VCR Logo
Popular Tags
135 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca8320 powers vhs plays record dvd
  • Televison & Video
