20 Most Recent
RCA DRD485RG DirecTV DTV Receiver Questions & Answers
Parental lock code has been lost how can i unlock
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
My itv channels keep breaking up or freezing since
I'm guessing the signal from the antenna is too weak. With digital, it will not get fuzzy as with analog, but rather will pixelate, go blank, or freeze. You need to figure out how to get more signal to the TV by moving or re-aiming the antenna, improving the connections (clean or repair), or amplifying the signal.
No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem.
Tell me if this works for you?
Absolutly no signal on any transponders, all @ 0
i suppose the the "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to.
Hi
Have questions about your upgrade? We've got the answers.
What do I need to do to receive my upgrade?
Nothing! Just make sure your DIRECTV HD DVR is continuously connected to your land-based phone line and you will receive the upgrade automatically.
When will I receive my upgrade?
The 6.3 software upgrade will roll out over a period of several weeks. Customers with more than one DIRECTV HD DVR may receive their upgrades at different times for each receiver. We appreciate your patience while we deliver these new and improved features to eligible DIRECTV HD DVR customers nationwide.
Are all DIRECTV DVRs receiving this upgrade?
No. DIRECTV DVR models SONY SAT-T60, PHILIPS DSR6000R and HUGHES GXCEBOT will not receive the 6.3 software upgrade. Other models received a similar upgrade, 6.2, in the past.
I have a DIRECTV R10 DVR with 6.1 software. Will I receive this upgrade?
No. The 6.1 software on the DIRECTV R10 DVR already includes the 6.2 features such as folders and faster menu scrolling.
Will any of my DVR settings be changed as a result of the upgrade?
Yes, some of your settings or preferences will be changed back to the factory default settings as a result of the upgrade. These include: "Favorite Channels," "Channels You Receive," "Spending Limits," "Clear Channel Banner Quickly" and "Dolby Digital" recording and output.
To change Channel Banners, Channels You Receive and Favorite Channels preferences:
1. Select "Messages and Setup"
2. Select "Settings"
3. Select "Channels"
To change Spending Limits:
3. Select "Parental Control"
To change Dolby Digital Settings:
3. Select "Audio"
4. Select "Dolby Digital" and "Digital Output"
Will I be charged for this upgrade?
No. We're upgrading your DIRECTV HD DVR as part of your normal DIRECTV® DVR with TiVo® service at no additional cost.
What happens if I don't have my phone line plugged into my DIRECTV DVR?
You will not be able to receive the upgrade if your DIRECTV DVR is not connected to your phone line. To install the upgrade, your receiver must successfully make a call to our servers.
How will I know when I have received my upgrade?
You'll receive an on-screen message the first time you visit DIRECTV Central after your upgrade is complete. It will also appear in your Messages section. You can also check your System Information screen to find out which software version you currently have.
Will the download delete any of my currently saved programs?
No. All of your saved programs will still be there for your enjoyment after the installation.
Once your upgrade is complete...
How do I activate the Grouping (folders) option?
1. Go to your Now Playing List.
2. Press Enter on your remote control.
3. Change groups to ON.
SHORTCUT HINT: While viewing your Now Playing List, press number 2 on your remote control and your Now Playing List will change from the GROUPS view to show each individual recording. Press 2 again and it will switch back to the GROUPS option.
How do I sort alphabetically instead of by date recorded?
3. Change sorting option to Alphabetical.
SHORTCUT HINT: While viewing your Now Playing List, press number 1 on your remote control and your Now Playing List will change from alphabetical to date sort. Press 1 again and it will switch back to alphabetical sort.
Some settings will restore to factory defaults when the new software is download
Satellite Receiver Malfunction
Go into the menu and check the signal strenth to see if its going up and down or if its a stead as a rock. I have seen this problem be the reciver as I was a satillite contractor for 5 years in the past and I have installed 1000's. I have also seen your poblem be a small brance in the distance cause the freezing, also a bad connector from the lnb on the dish to the multiswitch, or a bad connector on the back of the reciver or even a pinch in the wire but the most common thing I have found would be a loose connection on the back of the reciver with the fitting wasent screwed on all the way.. If the signal is rock steady, the reciver will need to be replaced as the recivers dont pay to be repaired. good Luck
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI
copy and paste link for manual
https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them.
Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse .
TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com
Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
What is the code for remote control for RCA model# RT 1971-AC
Better idea
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com
https://www.amazon.com > Replacement-DETG160R-...
Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control.
US$32.99 · In stock
RCA RT1971AC Replacement Remote
Remotes.net
https://www.remotes.net > products > replacement-rem...
If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems.
US$34.90
RCA Universal Remote Codes:
- The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
- The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
- The cable box codes are: 000 and 027.
Apr 26, 2023
