20 Most Recent
RCA P60921 60" Rear Projection Television Questions & Answers
Double halo in picture and writing
replace box in side tv, about a size of a cell phone,may little bigger than that the. cost for the part is about $200.00 or it call the moduler,tv can replace, if you move the tv, make sure u undo the wires 1s ,, why u ask some of these wire don't bend and brakes the box, it cracks,,it ,, that what the picture don't look correct, it looks like a bow and double view
I need the plastic screen
I am having the same problem, but have you been able to find out where to buy the screen for this yet. I really need to know. Thanks.
RCA 60921 rear projection tv.
Bad FBT Flyback Transfomer.You need to also check the Hori output Transistor,chances are if FBT is bad then Hori output will be shorted.
Mats Electronics should have FBT 1-800-628-1118
ACME 1-800-575-9833
I have a 60 inch
what it is the tvs like this are mento be serviced every 3 years or so the convergence settings are in the back only user ones are in the settings dont try this yourself though i broke mine lol it will cost 120 pounds tops to fix dont worry its worth it if this has helped please give me thumbs up because people are just taking answers and not voting
TV keeps shutting off on its own
I
need to assume you are a DIY and have some electrical experience. If
you aren't comfortable taking apart on of these TV's then you should
call an expert. If you are comfortable, then read on.
It has
been my experience with older rear projectors that the solder joints on
the main board become cracked over time. If you have a set that shuts
down after warming up, you might be able to check the board for bad
joints.
Always be careful when working on these old beasts. I
would always unplug them and let them sit over night to discharge a bit
before opening them up. The picture tubes still hold a charge so be
careful.
Cold solder joints or cracked ones can be seen with
really good lighting. Look for a half moon shape on the solder joint,
epically on the large transistors near the heat sinks. Be careful not
to cause solder bridges when you are touching up the solder joints.
Hope this helps.
RCA Projection TV Model P60925BL. Has sound but
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Our 60 inch will not
If you are getting power to the unit but have no picture, it sounds like the bulb has blown.It is usally located in the rear corner on the back of the unit. I have a samsung rear projection tv that did the same thing and I found it was the bulb that had given up. They are readily available on Ebay for around the $200 mark. The bulb itself is housed in a removable panel that is secured to the rear of the tv, usally 4 screws and it simply slides out. If you have a look at the back of the tv, down towards the bottom, you should see the panel I am referring to held in place by the screws.
Hope this helps somewhat,
Steve.
Screen looks like a bowtie
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
I have a 60 in
When there is sound but no picture, that is usually due to a faulty dmd board. A manual would be helpful in locating the dmd board so you can test it with an analog meter to find out if the capacitors are faulty on the board. This is fairly common in projection tv sets.
I was watching tv turned
The set has failed either in the power management circuits or, more seriously, one of the deflection systems has failed.
The turn on sound is the power management system trying to switch the power ON relay; the current monitoring system is detecting excessive current drain from somewhere in the set and turning itself off. These are among the most serious problems that a set can have.
You can actually reset your tv by unplugging it for a few hours. A full reset requires at least a 4 to 6 hour disconnect of the power cord.
Have an RCA 60
It is the 169 chassis-over 300 different models used it and are different-answer something for me--does it have a GREEN power light that comes on for a second and goes off?
I know this set well and to be honest hated working on them--Let me know about the power light and I will tell you what I know.
At one point in time this was a very good set--I do understand about paying a lot to get it fixed and having it bad again.
I am here to help people and I bet I know more about this set than almost anyone else here.
SD TECH
