20 Most Recent RCA HD61LPW175 61" Rear Projection HDTV Questions & Answers
0answers
Dolby digital when turn on tv go black toshiba 52" what can i do to fix it
if you have projection lamps in it they may be going out.
6/28/2012 1:46:29 AM • RCA HD61LPW175... • Answered on Jun 28, 2012
0answers
2answers
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
4/20/2011 9:00:10 PM • RCA HD61LPW175... • Answered on Apr 20, 2011
I have HD61LPW175 and after watching for about 45
Sounds like a bad color wheel. Getting ready to replace my own. The bad problem here is finding a new color wheel as many are "no longer available".
11/28/2010 2:44:00 PM • RCA HD61LPW175... • Answered on Nov 28, 2010
JUST CHANGED THE LAMP BULB AND THE TV IS NOT
Try reionstalling the lamp and make sure that the access door is secured correctly. Not securing the door will stol the lamp from working as projector and TV makers are concerned about the risk of fire.
11/25/2010 7:50:25 PM • RCA HD61LPW175... • Answered on Nov 25, 2010
The screen for my TV went out. The blue power
Lamp PN# 269343 Call Mats 1-800-628-1118
9/30/2010 4:03:22 PM • RCA HD61LPW175... • Answered on Sep 30, 2010
Screen display is green dominent
No, Problem is Bad Light Engine.
Encompass Parts Distribution 1-800-638-3328
9/21/2010 1:51:58 PM • RCA HD61LPW175... • Answered on Sep 21, 2010
RCA DLP HD TV was working fine then we heard a
Hi:
Replace the LAmp it has blown,
8/24/2010 4:33:18 AM • RCA HD61LPW175... • Answered on Aug 24, 2010
Trying to hook up hmdi cord to my tv can't find
If you have the RCA Owner's Manual they should have a diagram there.
6/5/2010 2:58:05 AM • RCA HD61LPW175... • Answered on Jun 05, 2010
When i turn my tv on it makes a loud non stop
YOU HAVE A DEFECTIVE FAN OR COLOUR WHEEL
5/31/2010 6:22:12 PM • RCA HD61LPW175... • Answered on May 31, 2010
Picture all of a sudden went distorted on top and
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
5/30/2010 5:37:49 AM • RCA HD61LPW175... • Answered on May 30, 2010
No convergence
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
5/30/2010 4:49:16 AM • RCA HD61LPW175... • Answered on May 30, 2010
My 52 inch RCA Home Theater Primiere will not turn on.
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
5/29/2010 7:44:14 PM • RCA HD61LPW175... • Answered on May 29, 2010
I have a 52 inch RCA DLP t.v. I have replaced the
Chances are YES! Call Encompass Electronics for Price and if they have any in stock or visit on their website 1-800-638-3328 You can call UED is another outlet 1-800-648-6657
10/5/2009 2:58:47 PM • RCA HD61LPW175... • Answered on Oct 05, 2009
NO PICTYURE OR SOUND LIGHGTS ON FRONT COME ON BLINK FIVE TIMES THEN GO OUT
Thats a common problem with the RCA ATC336 Power supply when the capacitors fail on the AC in power board. You can get the repair kit at the following link which will usually repair that symptom.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
5/23/2009 1:46:38 PM • RCA HD61LPW175... • Answered on May 23, 2009
Tv wont turn on
it sounds like your flyback transformer or voltage trippler is bad
5/1/2009 2:58:16 PM • RCA HD61LPW175... • Answered on May 01, 2009
RCA HD61LPW175 61" Rear Projection HDTV Logo
37 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
screen tv went out blue power
  • Televison & Video
