20 Most Recent Broksonic CCVG297 9 in. TV/DVD Combo Questions & Answers
How do I get to menu with out remoe control?
you may have to find a remote from a used store and/or someone who had one.
1/4/2015 7:21:57 PM • Broksonic... • Answered on Jan 04, 2015
I need a universal remote code for a Broksonic
Hello. contact broksonic directly. They have codes that no one else has access to http://www.broksonic.com/
Joe
5/7/2010 2:50:53 AM • Broksonic... • Answered on May 07, 2010
2answers
Need remote codes to enter into my verizon fios remote
what kind of equipment is it? cus you can go to verizon.com go to fios tv then installation then support and click on remotes then get codes for yada yada yada/
3/26/2009 2:46:46 PM • Broksonic... • Answered on Mar 26, 2009
Incorrect Disc message comes on when inserting a DVD
Clean the laser lens
1/20/2009 2:06:18 PM • Broksonic... • Answered on Jan 20, 2009
Tv on/off and volumn don't work on my dish remote
If you are trying to use a Dish Network remote control, then you are probably out of luck. Most Dish remotes do not have remote codes for TV/DVD or TV/VCR combos. There are just too many codes out there to put into one remote control. I'm sure they tried to walk you through a code search (hold the TV button down, etc.), so if it didn't show up then, then you are probably stuck with using two remotes or adjusting manually.
If they didn't try a code search, then try this:
Turn the TV on manually. Then, press and hold the clear TV button at the top until all the buttons at the top turn red, then release. Press and release the TV power button (the smaller red power button), and press the channel up button. Repeatedly press and release the channel up button about once a second until the TV turns off by itself, then press and release the # button at the bottom right hand corner of the remote, and the TV button will flash 3 times, confirming that it took the code. Press and release the clear SAT button at the top left, and then you should be good to go.
If the TV never turns off during the code search, and the TV button at the top of the remote flashes a bunch of times everytime you press channel up, then there are no more remote codes. The remote does not have the code for your TV.
Hope this helps you.
1/6/2009 2:53:02 PM • Broksonic... • Answered on Jan 06, 2009
Fios Remote Code for Yamaha SOund Projector
call the 888-553-1555 that is the fios solutions center
12/16/2008 2:57:53 AM • Broksonic... • Answered on Dec 16, 2008
Manual
Go to http;//audio.manualson line.com maybe there you find the solution
7/6/2008 4:13:17 PM • Broksonic... • Answered on Jul 06, 2008
My dvd Player isn't reading DVDs
you need one CDclener & DVDclener go to the shoop end your problem is finys
11/1/2007 7:55:35 PM • Broksonic... • Answered on Nov 01, 2007
CCVG297 broksonic 9" TV
When the channels show up in red thats an indication that they are not programmed into the TV set. Your going to need the original remote, go into the menu and then press auto scan with an attenna attached to the set. If it wont scan then you have a bad microprocessor
9/25/2006 7:02:44 PM • Broksonic... • Answered on Sep 25, 2006
Looking for a universal remote code for my broksonic TV dvd combo sc975
try these: https://www.eliztech.com/remotes/codelists/broksonic-tv-codes
9/18/2022 4:35:06 PM • Broksonic... • Answered on Sep 18, 2022
All I want is connection information a Broksonic VCRDVD player Model DVCR_810
If you wish to get some details; check the site linked here. Pull up older posts. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in either WebView, or by desktop. MobileView has no search box...
4/16/2021 2:20:00 PM • Broksonic... • Answered on Apr 16, 2021
Manual for broksonic DVCR 810 series A
Have a look on the gargler.Google it.
2/7/2021 4:48:50 PM • Broksonic... • Answered on Feb 07, 2021
I need a manual for an operating manual for a Broksonic DRVCR 900A. Can be a hard copy or download.
notify manufacturer or online search
12/28/2020 12:01:41 AM • Broksonic... • Answered on Dec 28, 2020
2answers
I'm trying to connect a converter box to a broksonic TV. All connections look right but the channel search is not pulling any channels. I also have an antenna connected. I need some advice, I must be missing a step.
Without more details there is only a couple of conclusions - maybe the set top box you have is faulty or incompatible in some way with either the tv or the antenna. Incompatibility with the tv seems unlikely as presumably the on-screen menus generated by the box are displayed satisfactorily - allowing you to select a menu, scroll and select an item and then view the channel seeking process. If this is so it suggests the connection between the box and tv is good. That rather suggests the box is faulty or the antenna is faulty or incompatible.
9/12/2020 7:21:30 PM • Broksonic... • Answered on Sep 12, 2020
Cant get my broksonic flatscreen tv model#ccvg2439 to link to my android phone using the hdmi adapter can you help me
https://www.youtube.com/watch?v=HLE_Qcy3z50
4/17/2020 7:41:14 AM • Broksonic... • Answered on Apr 17, 2020
Set tv input source for broksonic tv ccvg-1935. cable box remote works but when i turn tv to channel 3 still no picture
If you got sound did you connect the yellow plug for video?
8/18/2019 7:17:17 AM • Broksonic... • Answered on Aug 18, 2019
Broksonic tv: how to turn off and on manually
Hi Donna, indicate the model of your TV Brokcsonic, to be able to find the best possible solution to your answer You should look for the controls to be able to turn on and off of your TV, by the sides or the bottom of the TV, there are times that are in the back Try the contour of the TV to see if you place it, apart from the control of power on and off, should be those of changing channels, volume, menu and inputs I hope you find the controls, but send me the model of your TV and I will look for the best possible solution Greetings Franco Dosil Hola Donna, indica el modelo de tu TV Brokcsonic, para poder encontrar la mejor soluci?n posible a tu respuesta Deber?as buscar los controles para poder encender y apagar de tu TV, por los costados o la parte inferior del TV, hay veces que se encuentran en la parte posterior Tantea el contorno del TV para ver si lo ubicas, aparte del control de encendido y apagado, deber?an estar los de cambio de canales, volumen, men? y entradas Espero encuentres los controles, sino env?ame el modelo de tu TV y buscare, la mejor soluci?n posible Saludos Franco Dosil
5/28/2019 6:58:05 PM • Broksonic... • Answered on May 28, 2019
Broksonic CCVG297 9 in. TV/DVD Combo Logo
Popular Tags
17 questions posted
Top Broksonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Broksonic Televison & Video
Most Popular Question
get menu out remoe control
  • Televison & Video
