20 Most Recent RCA F35673MB 35" TV Questions & Answers
0answers
My tv wont pick up cable signle?
Possible bad tuner in the set if rear inputs function well.
12/17/2012 7:17:02 PM • RCA F35673MB 35"... • Answered on Dec 17, 2012
I cant get my tv to set for cable?
Either its set not to cable in the menu or you may have a bad tuner which was not uncommon in this set.
12/17/2012 4:48:57 PM • RCA F35673MB 35"... • Answered on Dec 17, 2012
Why does my tv show an unsueable signle?
That is the set not seeing signal, Its possible the tuner in the set is bad and first thing is see if a DVD etc connected to a rear audio/video input works---if so with a Cable box connected with audio/video outputs to one of the same kind of inputs on rear of set you can bypass the tuner and get around the problem.Replacing the tuner if it is bad could be rather expensive.
12/17/2012 3:34:34 PM • RCA F35673MB 35"... • Answered on Dec 17, 2012
White line vertical run acroos
hi;
there's a problem in Vertical parts of your TV, there is an IC that controls vertical alignment
of your screen, if this IC is fails the result is white line in the center of your screen
you see this IC inside the TV . you need some tecnical know how when servicing this unit
because there is a present of High Voltage inside. beter call for tv technician for repair.
9/5/2011 11:59:30 AM • RCA F35673MB 35"... • Answered on Sep 05, 2011
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
7/22/2011 12:49:18 AM • RCA F35673MB 35"... • Answered on Jul 22, 2011
Tem um capacitor que torrou mas nao consiga saber
Ol?
Da qual esta se??o capacitor ??. Capacitores normalmente grandes vir?o na se??o Regulador de pot?ncia. Se o capacitor que voc? descreve aqui ? ao lado do principal regulador de energia, ser? de 330MFD 450VDC ou 450VDC 220MFD. OK
6/27/2011 3:44:32 PM • RCA F35673MB 35"... • Answered on Jun 27, 2011
Will any universal remote work
Hello
Jusy buy one Philips Universla Remote control. RCA is listed in its codes list. The model number is [PHILIPS CL 034]. Codes and proceedings are given.
0704 0002 0406 0007 0011
................. 0611 0811 0312 0514 0720
................. 0102 0502 0601 0817 0917
................. 0835 0901 0103 0803 0211
................. 0912 0114 0519 0320 0420
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
OK.
1/4/2011 3:02:26 AM • RCA F35673MB 35"... • Answered on Jan 04, 2011
Humming noise when turned on. no picture. is
There is no reset for this kind of problem. The chances are that the flyback transformet is shorting, horizontal output transistor is bad, or possibly bad power supply board. The unit will have to be opened up and troubleshot. Some RCA units seem to be prone to this problem, and a friend of mine paid $300 twice within 6 months, so I can't vouch for RCA's long term reliability.
Hope this helps.
10/26/2010 12:54:22 AM • RCA F35673MB 35"... • Answered on Oct 26, 2010
RCA F35673MB won't turn on and makes a high pitch
The Horizontal Output transister is shorted and may have been caused by a bad flyback.
1/31/2010 8:07:06 PM • RCA F35673MB 35"... • Answered on Jan 31, 2010
Need to know what kind of egauss thermistor for a rca
Have found an RCA part number 207768 for the thermistor RT4201K
Not sure it will fit your model but should.
1/2/2010 10:44:46 PM • RCA F35673MB 35"... • Answered on Jan 02, 2010
Want to hook up DVD
The Red & White Cable must be plug into the Audio IN of the TV RCA jack this is for Left & Right audio. The Yellow must be plug in into Video Input of the TV for the picture. If you select the AV1 as your DVD input, to view it you must set the tv to AV1.
7/20/2009 9:39:32 PM • RCA F35673MB 35"... • Answered on Jul 20, 2009
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
2/27/2009 12:05:04 AM • RCA F35673MB 35"... • Answered on Feb 27, 2009
Only receiving Channels 50 and above; no lower channels
It could be anything from corrupted data in the EEPROM (a memory IC that stores all the channel information and picture settings) which is usually caused by bad ground solder connections inside the tuner itself which is built into the main circuit board and would have to be repaired, not replaced or components inside the tuner section of the main PCB. With that being said - if you have to get a technican to come to the house and repair the set then it would probably be best to buy a new HDTV set. If you can take it to a repair shop capable of fixing the tuner, it could cost close to $200 to repair is my guess, and may work OK for another year or two before the picture tube finally wears out.
12/19/2008 4:05:04 AM • RCA F35673MB 35"... • Answered on Dec 19, 2008
The picture is drawn in from the sides
this problem we cal vertical fault..cause by capasitor is not in good condition at vertical area or loose solder at the vertical ic
12/9/2008 3:45:33 PM • RCA F35673MB 35"... • Answered on Dec 09, 2008
Volume goes up all on it's own
the key wire will disable the contact buttons , but it may be the sensor that is doing this and it would need to be replaced or even the crystal on the eprom or the eprom when connections are attached
have you made sure that the plastic buttons are not pushing on the contact button
did you or can you check the sensor with the diode check on the digital volt ohm meter?
11/27/2008 2:33:38 AM • RCA F35673MB 35"... • Answered on Nov 27, 2008
Mind of its own
If you press MENU often enough, you will find and AUTOMATIC TURN ON FEATURE, also called ALARM feature. You can set it to Disable and this should cure your problem. You can also set times when it turns on automatically.
Does this help?
11/26/2008 3:50:16 AM • RCA F35673MB 35"... • Answered on Nov 26, 2008
Picture getting small blacking out
Yes you sound like pincushin is failing on you. Soon it will knock out horiz. output caps and Diodes. Needs repair soon.
11/26/2008 3:47:47 AM • RCA F35673MB 35"... • Answered on Nov 26, 2008
Horizontal lines
This may be a CRT Board ( the board mounted on the back of the picture tube) Also could be a shorted Piture Tube.
Ed
NC Electronic
Mills, Wyoming
10/28/2008 12:36:40 AM • RCA F35673MB 35"... • Answered on Oct 28, 2008
Televison & Video Logo
35 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
white line vertical run acroos
  • Televison & Video
