20 Most Recent
RCA F27442 27" TV Questions & Answers
TV has no sound
Hello
You haven's specified nothing about the picture. Picture is Ok and there is no sound I thinks and posts this solution
Either your TVs speaker or its sound out put ic has damaged. To check it and conifrm you just do this first. There is a stero headphone socket on the front panel of your TV. Insert a headphone pin inot it and listen whether there is sound output come ffrom it or not. If there is sound output from the headphone socket, and not from the speaker, be sure taht the speaker is out.
If there is no sound output from the headphone socet, wither your TVs sound output ic is damaged or it doesn't get proper voltage to go on. It is very easy to locate this IC, as speaker wire goes directly to this section. Just follow the speaker wire and locate the IC, usually screwed on to a metal heatsink. Check its input voltage. If there is no voltage to that IC, check the track associated with that pin. If there is voltages and still not works. first resolder all the pins of that IC by applying a little more solder, whout shorting the adjecent terminals. If this does not helps, replace that IC with same type and number. OK.
Zenith tv is blurry
There are two adjustments on your flyback. If there is not an access in the back of the set to turn the adjustments then you need to take the back off of the tv. One adjustment is for brightness and the other is your focus. Just slowy turn the adjustment right or left until the picture gets clearer and your done.
No remote. how do i know what remote to buy ?
Setup codes for RCA brand TVs are given below. If you want more details and codes to various remote controls, check the sites given here. Just enter them, and see which one has setup codes to RCA brand TVs, and buy one according to availability.
Check these
sites.General setup codes to RCA TV are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162
0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Picture too low in screen
Picture too low in screen can be from a circuit inside the TV.These can be caused from among the components in it.Here is a sample image to describe it :
Guide on How to find Vertical IC
and these Vertical IC derives power from
Flyback Transformer
There is no manual adjustment for Vertical height, these requires servicing.( a component level troubleshooting )let us know if you need further assistance!
