20 Most Recent RCA 27F650T 27" TV Questions & Answers
manual
27F650T 27" TV Manual
RCA 27F650T 27" TVUploaded on Jul 01, 2014
My 32inch RCA has a childlock and i dontknowhow to
See the instructions on page 21 of the manual available at http://www.retrevo.com/support/RCA-27F650T-TVs-manual/id/402dj495/t/2/
8/6/2013 6:31:45 AM • RCA 27F650T 27"... • Answered on Aug 06, 2013
MODEL #27V513T
You must have its remote control to unlock it.
1/24/2013 10:40:06 AM • RCA 27F650T 27"... • Answered on Jan 24, 2013
I NEED HELP GET THIS FPA LOCK OFF I DON'T HAVE A REMOTE FOR THE TELEVISION HOWEVER I HAVE CABLE I WENT IS FAR PUT MENU BUT IT WON'T SCROLL
You are going to have the original remote and the owner manual to do this--Universal remotes never had or will have key features the original one has.
4/12/2012 10:07:55 PM • RCA 27F650T 27"... • Answered on Apr 12, 2012
HOW DO I GET FPA LOCK OFF W/OUT NO REMOTE
You must have its original remote control to unlock this Tv. It wont work with universal remote control.If you have't the original remote control, just buy a new one, borrow it from any of your friends or relatives, who own the same model RCA tv; just to unlock it. For details about the proceedings to unlock it, get into this blog site. Details are given there.electronicshelponline(.)blogspot(.)com in name Electro-Help
4/12/2012 2:05:53 PM • RCA 27F650T 27"... • Answered on Apr 12, 2012
Is this tv digital ready?
yes
7/18/2011 2:35:43 PM • RCA 27F650T 27"... • Answered on Jul 18, 2011
I have 27f 650 t
hi there! if you know how to troubleshoot technically this will solve your problem.
1.check the horizontal section of your tv , there you will see the flyback system connected at the back of the picture tube, never touch it because there still a remaining voltage charge on it , electric shock might happens if you remove it improperly.
2. check all the components inside the horizontal section only & look for possible cold solder at board and fix it if you know how to use the soldering iron and Pumps.
3, replace the defective component if necessary thru the help of expert tv technician in your area. Thank You
2/7/2011 6:40:51 AM • RCA 27F650T 27"... • Answered on Feb 07, 2011
Purched this TV a few years ago for my mother.
If the picture here represents your TV's actual looks,a shop will have to come out.That is at least $50 for them to show up.1 hour labor@ $50-$60.Repair centers normally have a minimum parts price mark up of 20%.If you actually have a flat screen,it probably isn't worth repairing either because you can probably get a new one for around $350,new warranty and all that.I am just giving you the numbers and letting you decide but I am pretty sure I know what that will be.I joined here to inform and educate people who can be ripped off by industries without knowing it.I have seen too much of it and it's disgusting.Good luck,Greg
1/5/2011 9:55:56 PM • RCA 27F650T 27"... • Answered on Jan 05, 2011
When turning the tv on
Hello
It is due to the tuner trouble of your TV. Technicaly it is known as tunig drift. Some tuneres will exibit this problem. It will be ok after some time, and will go normally. It will differ according to atmospheric temperature and mostly depends on humidity.
Replcing the tuner with same type and number is the only remedy. Tuners ar not repairable. Replace it. OK.
1/4/2011 2:00:25 PM • RCA 27F650T 27"... • Answered on Jan 04, 2011
My fpa lock is on
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
12/24/2010 12:21:47 PM • RCA 27F650T 27"... • Answered on Dec 24, 2010
How do i put the plug from the wall into the back
Hi, my name is John. Welcome to FixYa. Are you going to do this yourself?.John
12/7/2010 2:31:05 AM • RCA 27F650T 27"... • Answered on Dec 07, 2010
Picture is over sized
Hi:
IF you are on a cable box check the cables remote for a aspect button or format button. you may be in zoom mode. also check your tv's remote for the same buttons usually on rca remotes the left arrow key is the picture format button.
11/9/2010 1:30:21 AM • RCA 27F650T 27"... • Answered on Nov 09, 2010
Unlock child lock
Unknown password--ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
4/15/2010 6:29:37 PM • RCA 27F650T 27"... • Answered on Apr 15, 2010
The rca tv and converter box were working. Now only fuzz on the
one try is to unplug the tv and then hold the power button in for 20 seconds then plug the tv in an see if this works. I had a 32 in rca tube an this worked for me
3/18/2010 12:43:57 AM • RCA 27F650T 27"... • Answered on Mar 18, 2010
TURNS ON OFF AND SAYS(UNUSABLE SIGNAL) AND FUNCTON DISABLED WHEN
eeprom memory corrupted change it
1/6/2010 2:55:35 PM • RCA 27F650T 27"... • Answered on Jan 06, 2010
3answers
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
11/4/2009 6:07:10 PM • RCA 27F650T 27"... • Answered on Nov 04, 2009
RCA HD27F754T 1 Solid Red Light, then,
HI. this may be a fly back situation. this is a transformer that is located on the power board section of your set. This device stores and, distributes the necessary AC current needed for proper CRT performance. There is also a horizontal deflection chip that will shut off the transformer if it becomes unstable as well.
I recommend checking the Horizontal deflection chip for damage. if this chip is in good condition, replace the HV Fly back transformer.
6/26/2009 12:43:43 AM • RCA 27F650T 27"... • Answered on Jun 26, 2009
RCA 27F650T 27" TV Logo
Popular Tags
49 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
32inch rca childlock dontknowhow
  • Televison & Video
