20 Most Recent RCA F32450 32" TV Questions & Answers
2answers
No red
Losing one colour probably means failure of electronic components related to the particular colour. It is unlikely adjusting the red settings will fix the problem. Even if it did, the colour balance needs specialist equipment to properly set up.
12/28/2014 8:18:01 PM • RCA F32450 32"... • Answered on Dec 28, 2014
Old television will not turn on
Check and replace damaged component/s at its main power regulator section circuit. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
1/7/2014 8:49:41 AM • RCA F32450 32"... • Answered on Jan 07, 2014
3answers
RCA Guide plus gold gemstar T.V
I have a guide plus gold gemstar tv and I cant program my direct tv remote or Innovage jumbo remote to operate the tv, can anyone help?
7/9/2013 8:51:39 PM • RCA F32450 32"... • Answered on Jul 09, 2013
The tv continuously changes channels and the tv's on top buttons won't work accept for the volume up
Check for any struck press buttons at the control panel of the TV. This is a common fault that, these switches to get struck, preventing any more functions to do with them. There is no repair to these micro-switches, except replacing them. You have to open your TV to access this control panel printed circuit board, de solder out these damaged switches, and to solder new ones in place. It will be best to replace them all at one time. These switches can be bought from most of the electronic spare part selling shops at your town. if you are not handy with electronics, seek help of any experienced service technician.
8/5/2012 8:39:03 AM • RCA F32450 32"... • Answered on Aug 05, 2012
How to make a remote responed to a rca tv model f32450
HelloSetup codes for RCA TV are given here. Try with them, and get the proper code, y which you can get more functions to operate with:Three digit codes for RCA TV are:000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194 Four digit codes are:0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188 Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. Five digit codes with RCA RCR 312W remote control are:10000, 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187
2/13/2012 8:12:35 AM • RCA F32450 32"... • Answered on Feb 13, 2012
My RCA model F27TF700 went
I am sorry to hear regarding the trouble. This is a common problems on these sets.The symptoms you mentioned highly suggests an issue with power supply board.If you have electronics repair experience and wanted to repair it, revert and i would be glad to add few more inputs to the diagnosis unless investment in new TV is the best option.
For about $250, you can buy a new 26" LCD TV.
It would cost about $200 for a repair.
I think it might be better to buy a new TV. If you do, buy the extended warranty, they don't make them like they used to.
Please let me know what you think, I could also give you a referral to a reputable shop if you give me your zip.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6/27/2011 12:48:51 AM • RCA F32450 32"... • Answered on Jun 27, 2011
No picture or sound. A continous high frequency
Hello
Line Output Transformer of your RCA tv has damaged. Never switch on the TV until this fault has retified. The transfrmer said above is called as {LOT} for short, and should be replaced with same type and number. Along with, its horizontal output transistor also shold be replaced. OK.
3/7/2011 4:10:15 PM • RCA F32450 32"... • Answered on Mar 07, 2011
I need to the price
You can get it from $170.00 at Amazon.
Hope this help
2/10/2011 3:02:44 PM • RCA F32450 32"... • Answered on Feb 10, 2011
Hey I got a dish network tv and the fuse looks
I hope that you have gotten this resolved. But in case you haven't or have some questions, here are some quick and simple steps to go through. Try unplugging the receiver from the power source for about 10 seconds. If your receiver is plugged into a surge protector, try plugging it straight into the wall if possible; or if already plugged into the wall, try to move the receiver to another outlet. The receiver at times will not get the full amount of power that it needs, and it will not stay powered on. If none of these work, you may need a new receiver. If this was not already taken care of, you can e-mail me at [email protected], and I can help you further.
Becki Barned
DISH Network Customer Service
1/19/2011 2:06:52 AM • RCA F32450 32"... • Answered on Jan 19, 2011
The tv won't come on...when you turn it on the
Hello
There is some short circuit in the horizontal output section inside your RCA tv. The blinking of ztandbylight twice denotes it. it may be due to a short in the horizontal output transistor, or defective LOT [Line Output Transformer]. Remove the horizontal aoutput transistor, by resoldering it out. It can be located very near to the above said LOT, screwed on to a metal heatsink. It is a three terminal device usually black in colour. After resoldering it out, switch on your TV, and see whether the standby LED blinks or not. If not, replace it with a new one, and switch the TV for a short time, say 3 seconds or so, and switch it off, unplug it from mains supply, and feel the heat of the transistor replaced. If it overheats, LOT said above is defective, and should be replaced with same type and number. OK.
1/8/2011 4:43:54 PM • RCA F32450 32"... • Answered on Jan 08, 2011
Will not power up. Just makes a high pitch wining
You have a high voltage problem that is loading the set down, the power supply is starting up and trying to start the set but can't because high voltage has one or more defective parts, needs technician.
1/5/2011 2:04:03 AM • RCA F32450 32"... • Answered on Jan 05, 2011
Good Morving I need remote and owners
Mats Electronics has Remotes 1-800-628-1118 or you can go to the Dollar Store and Buy the RCA 4 in 1 Remote with Code Book Most Common Code for RCA is 000 $6.00
Retrevo.com has Manuals
12/31/2010 3:13:23 PM • RCA F32450 32"... • Answered on Dec 31, 2010
Power light flashes on and
power light flashes on and off then stays on but no picture or sound
10/23/2010 10:19:06 PM • RCA F32450 32"... • Answered on Oct 23, 2010
RCA F32450 32" TV Logo
Popular Tags
138 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
  • Televison & Video
