Hello
You are locked out I thinks. To get out from this, one amoung the following method will surely help you.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
- Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
- Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
- Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
- Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
- Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds. OK.
