20 Most Recent RCA B27TF680 27 in. TV/VCR/DVD Combo Questions & Answers
2answers
Stuck dvd
Same problem! Go to EXIT on the remote. A pull down box will come down. It will have several choices. Choose DVD. From there you will see different operations. Choose eject or whatever u have for getting the disc out. Now the DVD screen won't go off. Just hit the "ch" channel button. Yuo are now back in TV mode. I learned by experimenting. Lady techie
4/26/2013 1:41:16 AM • RCA B27TF680 27... • Answered on Apr 26, 2013
My RCA TV has a
Hi.
If the picture is reduced to a band in the middle of the screen, then the alignment is gone. The convergence ICs must be replaced and parts in the circuit must be tested and eventually replaced.
The job cost is about $200.
1/4/2011 12:22:17 AM • RCA B27TF680 27... • Answered on Jan 04, 2011
Hi I have a tru flat dvd, vcr tv. I do not have a
11/30/2010 5:35:52 PM • RCA B27TF680 27... • Answered on Nov 30, 2010
2answers
Some channels have lost their sound. picture is
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by SAP selected on your remote control. Make sure you have selected Stereo or Mono in the audio menu. You can find all of this in your owners manual ( which you can probably download if you don't have it). Good luck, John
11/22/2010 3:00:59 PM • RCA B27TF680 27... • Answered on Nov 22, 2010
Can not insert vhs tape into player
Hi and welcome to FixYa,
Initially, there are only 2 possible reasons why the VHS tape could not be inserted:
  • another tape is inside or a foreign object is blocking the loading slot;
  • the loading mechanism has faulted in mid eject/load position.
Options then are:
  • consider a DIY (do-it-yourself) repair if and only if comfortable working with electronics / electro-mechanical components & circuitry, use of a DVM/VOM, a soldering iron/station and safe practices with electrically powered devices. Access to a Service Manual or at the very least, an exploded parts diagram would be a necessity;
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center or a qualified professional.
Offhand if a DIY is being considered, shine a flashlight towards the inside if the loading slot cover would grant even a small opening. While the repair if ever required would not be that difficult, it is extracting the VCR mechanism that would be a major challenge.
Good luck and thank you for asking FixYa.
4/28/2010 9:20:09 PM • RCA B27TF680 27... • Answered on Apr 28, 2010
Narrow picture
This would be the horizontal integrated circuit that is failing. Your going to need to take that in for repair, cost $75 bucks plus your part. There is not really much you can do from home to fix this and this is a non user friendly part.
Thanks hope this information does help please do click the accept button for my effort. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/10/2010 7:57:29 PM • RCA B27TF680 27... • Answered on Apr 10, 2010
Vhs tape won,t go into player
Brand and Model please
10/24/2009 11:15:33 PM • RCA B27TF680 27... • Answered on Oct 24, 2009
One of our channels has the audio off, and we
Go into the audio menu and make sure it is not in SAP (Special Audio Program) Mode.
10/24/2009 11:11:14 PM • RCA B27TF680 27... • Answered on Oct 24, 2009
TAPE WENT IN AND TROUBLE TO GET OUT, WHEN OUT,
If you "helped" the tape out in any way, that action most likely caused more damage. When a qualified technician sees an item before "customer induced damage" their job is easier and no "unusual" parts are broken which puts them in a good frame of mind and translates into a repair that you can be happy about.
However, if only the "eject" button was used to get the tape out, this is a fairly common symptom and worth taking to an experienced professional.
9/5/2009 10:18:52 PM • RCA B27TF680 27... • Answered on Sep 05, 2009
2answers
I NEED TO KNOW HOW
Hi
try the instructions posted on this page.
http://www.artofhacking.com/files/TVMODES.TXT
8/17/2009 1:30:01 AM • RCA B27TF680 27... • Answered on Aug 17, 2009
American DVD discs will not load and play, but overseas discs will
no the coding would not change from using the dvd's from overseas. the ones that you say are american may not be american and that is most likley the problem. try putting in a dvd that you have had for a long time that you bought here in the states and if that works then the dvds you say are american are the problem.
5/31/2009 3:48:39 AM • RCA B27TF680 27... • Answered on May 31, 2009
Need to know what channel my TV needs to be on to watch DVD/VCR
The channel you use depends on how you have the vcr/dvd player wired to it. If you used a co-axial wire, then your tv should be on channel 3. If you used RCA wires, then you will have a button, either on the front of the tv, on the remote, or both that says "input" or "source". Pressing this will change the TV to the rca connectors. Try this and let me know if it helps :)
5/16/2009 10:47:45 PM • RCA B27TF680 27... • Answered on May 16, 2009
The cable / antenna connector
You are from india means you can get in Electronics repair shop
5/3/2009 11:55:38 PM • RCA B27TF680 27... • Answered on May 03, 2009
Recording one cable channel, watching another
initialy this option is posible when we work with separate sets.
When the manufacture build-in a VCR into a TV or a TV to a VCR (applies too) we have a "clone" and funtions are share each other, so this clone only have one tuner and is not able to manage two signals at the same time.
4/15/2009 5:10:26 AM • RCA B27TF680 27... • Answered on Apr 15, 2009
Jail bars in picture on analog cable tv only
this kind of intermittent noise has to be researched in the bench specially because the lines are there and then go out. it can be any component false contact, or solder joins.
4/15/2009 5:02:21 AM • RCA B27TF680 27... • Answered on Apr 15, 2009
DVD went in...and won't come out
Whatever you do, DON'T try ejecting it manually. it can ruin the dvd mechanism. The problem is in the dvd power supply. If you have some soldering skills and are good with a soldering iron(temperature controlled is best) you can resolder all the three-legged regulators on the dvd power supply board(small board to the right front of chassis). Good success, Meder's Tv
3/29/2009 4:29:52 PM • RCA B27TF680 27... • Answered on Mar 29, 2009
DVD player says "wrong disc type"
Clean the laser.
3/20/2009 2:13:32 AM • RCA B27TF680 27... • Answered on Mar 20, 2009
RCA B27TF680 27 in. TV/VCR/DVD Combo Logo
34 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
stuck dvd
  • Televison & Video
