20 Most Recent
RCA RP8070 5-Disc CD Changer Questions & Answers
I have removed the five screws on the ba
If you can,t get it apart don,t evan waste your time on it any more , You can get a good used one for $7 to $30 at the most now a days, that is better then a (RCA)
Spindle motor don,t run have replaced complete
The optics assembly is shipped with a short across the laser to prevent static damage during shipping or installation. Make sure that you have opened up this short or the unit will appear like the optics are bad. The CD won't spin up unless a disc is detected which requires the laser to work.
Please keep up posted on your progress.
Dan
Disks are not detected
If the lens of you CD changer becomes weak then, you wont able to read discs that contains scratches or old discs..
Try using a good lens cleaner and try cleaning the lens, if you still have problem then you have to change the lens of your CD changer..This will solve your issue..
please leave me comment,if you need further assistance
Rnj VINODKUMAR
Music plays normally at first then begins to cut
There is a problem with the laser pic-up assembly(eye) 1st,2nd, 3rd,4rth music/track are recorded on disc from the center to edge.As the laser moves toward the edge the laser can't read perfectly the stored data on the disc. possible cause:the disc is in figure of 8, the lens needs cleaning, the suspension of the laser assembly,poor recording speed,spindle motor and voltage fluctuation of VCC
WILL NOT ROTATE
This is the result of a failed spin motor. have it replaced asap to correct this issue.
Wont play CD's
I would guess that either the lens is dirty or the optics are starting to fail. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Keep us posted.
Dan
Stuck in standby mode
The problem with your amp may be with the power ON circuit. On most stereos that have a standby light the standby power source is still OK. When you press the power on button the standby light will go out and the stereo will power up(turn on) as you should hear the click of the power control relay. If the unit will not power up you should check the power control relay circuit and/or the main power fuse that protects the main power transformer.
Turntable.
measure the total length of the belt, and I presume it is square. approximate the thickness and contact turntableneedles.com, they have about 450 belt sizes in stock.
