20 Most Recent
RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf System Questions & Answers
I need the owners manual for this and we need a
You can find the manual through Amazon.com
here. The original remote, RCA part number 268773, is no longer available. But a search for that number turned up several sources for suitable replacements.
Here's one I picked from the Google results (I have purchased remotes from these folks in the past), and
here's another for good measure (a better price, but I've never done business with them)..
Can you tell me how to change the clock on my RS2652?
press and hold the "CLOCK" button until the time flashes, the using the << & >> buttons, adjust the hour, press "CLOCK" once more to select minutes. again, using << & >> to select time. press "PROG. SET" once. good luck
Alarm
as im seeming to tell every1..lol (make/model plz)
RS2652C
I tilted the player to the right side (viewed from the front) to better see the speaker terminals and heard a clunk. When I sat the player back up I was able to open the drawer. I found two of the CD’s had fallen out of the proper holder on top of another CD (three CD’s in one space. After I put the CD’s back where they belonged the unit worked fine.
I assume one of the CD’s didn’t seat properly after playing and caused the mechanism to jam.
Hope this helps your problem.
Bob Michener
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
Can I burn a CD from a tape on an RCA Model # 8530?
The RCA Model # 8530 appears to be a stereo receiver, which means it does not have the capability to directly burn a CD from a tape.
To convert a tape to a CD format, you would typically need a separate device called a cassette deck with a built-in CD recorder or a computer with the appropriate hardware and software.
If you have access to a cassette deck with a CD recorder, you can connect the RCA Model # 8530's tape output to the input of the cassette deck and then use the cassette deck's CD recording function to transfer the audio from the tape to a blank CD.
If you have a computer, you can use an analog-to-digital converter to connect the RCA Model # 8530's tape output to the computer's audio input. You can then use audio recording software on the computer to capture the audio from the tape and save it as a digital file. Once you have the digital file, you can use CD burning software to create a CD from the captured audio.
It's important to note that the specific steps and equipment required may vary depending on the exact models and setup you have. It's recommended to consult the user manuals for your devices and, if needed, seek additional guidance from the manufacturer or a knowledgeable audio technician.
6/18/2023 4:27:03 PM •
RCA Audio...
Answered
on Jun 18, 2023
Sub-out on Kenwood VR-6060 NOT Working with powered subwoofer
It seems like you've tried various connections and settings to get your JBL135 subwoofer working with your Kenwood receiver, but you're still facing issues. Let's break down the situation and provide some recommendations:
- Subwoofer Connection:
- Using the LFE/Subwoofer Out: This is the preferred method for connecting a subwoofer. Ensure that the cable is firmly connected to both the subwoofer's LFE input and the receiver's Subwoofer Out port. Make sure you have enabled the subwoofer output in the receiver's settings menu.
- Subwoofer Settings:
- Gain: Adjust the gain knob on the subwoofer to achieve the desired bass level. Experiment with different settings to find the right balance.
- Crossover: Set the crossover frequency on the subwoofer to blend with your tower speakers. Start with a conservative setting, such as 80Hz, and adjust as needed.
- Receiver Settings:
- Speaker Configuration: Set your tower speakers to "Small" in the receiver's settings menu to redirect bass frequencies to the subwoofer. This ensures that the tower speakers are not trying to reproduce deep bass.
- Bass Management: Enable the appropriate bass management settings in the receiver's menu, which typically includes crossover frequency and speaker size adjustments.
- Check Subwoofer Cable and Port:
- Ensure that the subwoofer cable is in good condition and securely connected to both the subwoofer and receiver.
- Try using a different cable or testing the subwoofer with another receiver if possible to rule out cable or port issues.
- Factory Reset:
- If you've exhausted all troubleshooting steps, you may consider performing a factory reset on your Kenwood receiver. This will reset all settings to their default values, potentially resolving any configuration issues.
If none of the above suggestions work, it's advisable to consult the user manual for your specific Kenwood receiver model or contact Kenwood customer support for further assistance. They can provide more detailed guidance based on your equipment and setup.
6/18/2023 4:25:51 PM •
RCA Audio...
Answered
on Jun 18, 2023
Connect RCA cables to USB on home stereo
RCA is now generally considered as an old, rarely used system so most new stereo systems and TV's don't have them fitted. If there are parts missing from the setup you're trying to connect there is a good chance you won't be able to connect it to anything. New replacement systems can be reasonably cheap and much easier to connect to modern stereos and TV's.
4/4/2023 10:04:06 AM •
RCA Audio...
Answered
on Apr 04, 2023
