20 Most Recent
Samsung TXJ2879 28" TV Questions & Answers
Just got my Samsung tv
maybe during yesting the plug was pulled out from the outlet with turning it off first. some of remote controled appliances need to be turned off by remote control unit before unplugging it from power source., theres no big deal in that problem
Intermittent vertical
Find the vertical IC and just resolder all the pins and adjacent component pins. This will fix the problem, this is the result of a dried out solder joints.
Sharp
which way is it "closing" ? top & bottom moving towards center or sides moving in towards center? one is vertical problem the other is horizontal, let me know and I can give you an answer.
High pitch sound and fuzzy
The high pitched sound, probably not, unless you open this TV set and find out what is making the noise and replace the part. Most likely a coil or transformer is vibrating so fast that the frequency is very high. On the focus, possibly can be adjusted. Now when you take off the back of this TV set, i must warn you, follow my instructions to the letter as there is enough High Voltage in this set to make a grown man cry! After you take out all of the screws off the rear cover,carefully lift up the cover straight up. Oh by the way the TV should be face down. Opps! Not stand back up the TV set and there will be a Grey or black block like looking thing with a large red wire going to the top of the picture tube. on this block you will find two controls, one will say screen, and the other will say focus. DO NOT ADJUST ANYTHING ELSE WHEN YOU ARE IN THIS TV SET!!! No slowly rock the focus control back and forth till you get the sharpest picture. Put back on the back cover and enjoy!!! Good Luck
Having trouble with my Samsung television can you help please?
sorry silly girl seen this a hundred times!! The crt socket on the set needs to be carefully taken off and cleaned with wd-40 or tuner wash. its an intermittant connection on the screen contacts and the contacts that bias the grids.. It can be a green haze a blue haze or a red haze. Very common on 3 to 5 year old samsung tvs. Good Luck
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
Yesterday
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described.
Here are a few options you might consider:
- Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
- Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
- Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
- Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
- Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM •
Samsung...
Answered
on Feb 04, 2024
