20 Most Recent
Samsung TXE2746 27" TV Questions & Answers
Plano tv samsung txe2746
saludos tengo un problema en la fuente de alimentacion y exploto el integrado que esta unido a un disipador de calor precisamente en el serial del integrado quien me podria ayudar facilitando el plano electrico del samsung txe2746.
gracias
SAMSUNG TXE2746 Switch makes click sound and does not switch on
I was thrilled reading our kind Forumite's instruction on how to get my broken Samsung txe2746 wiht the above problem repaired. The cylinder specified located at C858 supposed to be numbered 470 turned out to be the wrong one. The one with that specification is C808 with the number 470, and 25V. Did I misread your instructions or it could be that mine is a different model? Should I go ahead and change the C808 just for the sake of trying. Is this recommended?
Picture tube
HELLO
If your tube has gone and you are looking to replace it - my advice is don't bother - it will cost you dear in the end. The best thing to do is try to get another CRT TV set (maybe a different make/model).
It is a skilled job replacing a TV tube and should not be attempted by anyone who does not know what they are doing!!! In the wrong hands a CRT is dangerous and could cause serious injury if dropped or handled incorrectly (it makes one hell of a bang).
I wish you luck with it all the same (:-)
Samsung TXE2746
this could be a number of problems first chek the horizontal output transistor this could be shorted and the set could be tring to turn on but cant couse of the short look for bad solder connections if this does not help check or replace the regulator
Trouble
I need more info please as i dont understand what your asking?? sorry
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described.
Here are a few options you might consider:
- Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
- Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
- Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
- Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
- Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM •
Samsung...
Answered
on Feb 04, 2024
