20 Most Recent
Samsung TXN3271HF 32" TV Questions & Answers
Tedelex TV
would it be reccomended to buy a tedelex tv
8/12/2014 8:49:05 PM •
Samsung...
Answered
on Aug 12, 2014
I will plug in my tv and no lights turn on at all
Check and replace damaged component/s at its power supply regulator [SMPS] section circuit. If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
10/16/2013 6:01:27 PM •
Samsung...
Answered
on Oct 16, 2013
No picture no sound, whats possible solution
No picture or sound means your TV is dead. There may be several causes, lies between power supply to picture tube base card. You should contact a proper service personal to make it live. Ok.
10/17/2010 2:29:16 PM •
Samsung...
Answered
on Oct 17, 2010
My tv appaears to be
Go through the menu and check the aspect ratio. Choose the ratio that was working OK for you.
Looks like user correctable setting. Check user guide also.
8/23/2010 6:35:09 AM •
Samsung...
Answered
on Aug 23, 2010
I have a RCA tv wont turn on and makes a high
Your TV is actually functioning but their is probably a leakage on high voltage supply.
Warning : The next procedure should be done by an expert.
1.Clean the anode cap mounted on the CRT.But before touching the cap be sure that the voltage stored in the CRT is discharge to avoid risk of electric shock.It is done by creating a path of conduction from anode cap to chassis ground.
2.After cleaning the anode cap and the CRT surface.Attached the anode cap to the CRT.Be sure after attaching the pins correctly push and vacuum the socket and the cap to seal leakage.
7/14/2009 3:05:49 PM •
Samsung...
Answered
on Jul 14, 2009
Not Available Flashing
My Samsung TXN3271HF had the same issue where the poorly-designed Soft-Touch channel button begin to register phantom touches (leading to the "Not Available" message flashing on the screen).
The fix is simple: remove the plastic strip containing the Soft-Touch buttons and when replacing the strip, leave some room between the buttons and the TV's circuit board (you will see the circuit board once you remove the plastic strip).
Hope this helps.
2/4/2009 1:33:29 AM •
Samsung...
Answered
on Feb 04, 2009
RE: 72034
two fuses one close to line cord entree. other inpower supply. area. will need ohm meter to ck. is set dead? not many symptons to go on.
12/4/2008 3:48:19 PM •
Samsung...
Answered
on Dec 04, 2008
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure.
1 reduce brightness as you will get h/line due to vertical failure.
2 check v/section for loose contact or yoke connection.
3 check supply to vertical section.
4 check associated parts in v.section
5 at last check for vertical ic.
resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor.
.5ohm to 10 ohm.
it burnt again due to short cht in vertical mainly due to ic.
hope this will help.
as per schematic diagram go to
www.serviceinfo.com
11/23/2008 1:13:04 AM •
Samsung...
Answered
on Nov 23, 2008
RE: 72034
dwijackie
TXN3271HF
September 21 2008
You have asked me where the fuse is located
The answer to that is , the fuse is locaed INSIDE THE SET on the chasis.
To find the fuse
1. You will need to look at the back of the television set where the power chord connects to the
chasis, the fuse will be located in that area.
Chasis in this situation means the board wich is located at the bottom of the television
and does not mean the CRT board attached to the picture tube.
Az.
9/22/2008 6:02:52 AM •
Samsung...
Answered
on Sep 22, 2008
