20 Most Recent Samsung PS42P2S 42 in. Plasma Television Questions & Answers
I found a video that hopefully will fix your PS4 problem "How to Fix:PS4 Controller Yellow Light Of *****".
Samsung PS42P2S... | Answered on Oct 14, 2019
Hi Trent, Please watch this video.
www.youtube.com/watch?v=za3EixgxBkk.
I hope it helps.
Good Luck
Samsung PS42P2S... | Answered on May 06, 2016
I also have that problem with mines but my HiFi has audio inputs and i use that for my audio and it works .
Defo weird
Samsung PS42P2S... | Answered on Aug 14, 2015
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
This is beyond what can be accomplished at home. Here is a web site that has a directory of business that can fix LCD. LCD area repair services
Samsung PS42P2S... | Answered on Jun 12, 2014
Same problem.damn inferior product.I knew I shouldve stick with sony.Ive had mine for 7 months and according to the guy I bought it from hes had it almost a year.No power
Samsung PS42P2S... | Answered on May 12, 2014
hidefhfhfieiikkfjjfkjfjgjhhfkdfeoighorwGHFD;OAHJLIEjhoierjhfbiufhlkvmnkfdljhbfiolksfhlksfjhflkdjfiglkhrfighflkjhgfjlkghifdhglkrjfkjgkgofjhopfjhoiigjpoehoierjoigehoierhpehirgerojhierhpoejhoruhieruoerpigoruhjpoerugrhureopgrepueophepupojrpoepupogririerpouheuhpoerporugporuorhurpoioerupoeueropupopoerpoerupoererupoepopoeugjrgrijgrijpjpperjjgerjrejuregjrrgihrggrgjjjjjfjfigoiriiririijjfifjjjifiihirguhguihgoijgoihfsgsjoighsfigohsoighskgjkfslghlkshskghs
Samsung PS42P2S... | Answered on Dec 04, 2013
Replacing procedure of bulb to projection TVs, are almost the same irrespective of Brand. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Samsung PS42P2S... | Answered on Oct 16, 2013
It sounds that the audio output IC overheats. This may happen if the contact between IC and its heat sink became loose. Check it.
Samsung PS42P2S... | Answered on Apr 25, 2013
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Samsung PS42P2S... | Answered on Apr 02, 2013
that could be the Speakers having an issue or the audio out circuit has an issue, Probably a main board issue
Samsung PS42P2S... | Answered on Aug 07, 2012
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Samsung PS42P2S... | Answered on Jul 01, 2012
I will presume it is a Plasma as indicated here----lines top/bottom or left right are not easy to fix as far as knowing what to replace.
Set has a main board that communicates with the screen and directs information there--can be in one of three general areas:
1. Main Signal board (most likely)
2. Power supply as voltages are critical (less likely)
3. Display panel (the screen unit itself with a defect inside it) the last is least likely but possible.
Samsung PS42P2S... | Answered on Jun 13, 2012
Samsung PS42P2S 42 in. Plasma Television Logo
165 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
39 re trying hook up ilive sound bar
  • Televison & Video
