20 Most Recent
HP Officejet Pro 8610 Wireless All-in-One Color Inkjet Printer A7F64AB1H Questions & Answers
How do I find the Printer IP address
Test the wireless connection Print the wireless test report for information about the printer wireless connection. The wireless test report provides information about the printer status, hardware (MAC) address, and IP address. If the printer is connected to a network, the test report displays details about the network settings. To print the wireless test report 1. From the printer control panel, touch (Wireless), and then touch Settings. 2. Touch Print Reports 3. Touch Print Wireless Test Report.
Print two sided paper
You need the accessory that permits two sided printing. Check HP web site for that part to make sure you have it and have it installed. Once installed, if you have the HP printer driver software installed and up to date for your computer operating system (PC or MAC), when you request a PRINT you will see PROPERIES button in the print dialog box. Tap that button and scroll down to TWO Sided Printing. That's it.
This is a setting that will only stay active for the current print job. If you want the default to be two sided printing you can set that in the HP Solution Center under Printer Settings.
Why doesn't paper feed from the tray to print?
There's a chance that the pick up roller has a lot of paper dust on it. You can get cleaning paper from an office supply. It is sticky on both sides of the sheet. You run it through several times to clean all the rollers on the printer.
Can I get total pages printed off HP Pro 8610? I am on Windows 8. Thanks,
When you did install the correct HP programs that came with the printer I think it should work. Uninstall the olde HP programs and doe a complete reinstall, before reconnecting the printer. That should solve the problem.
Always FIRST install the software, then connect the device to the computer.
