20 Most Recent
Tamron Macro 90mm f/2.5 Manual Focus Adaptall Lens Questions & Answers
Detaching Lens Hood
I'm not sure of the exact model number of your lens, but the hood should have a bayonet flange and rotating it in one direction or the other should allow it to then simply pull off.
Tamron 90mm 2.5 adaptall man focus lens
You probably have to set the aperture manually on the lens, because it
might not have CPU contacts. I think changing the aperture on the
camera will probably have no effect, so just try twisting the aperture
ring to wide open.
You usually have to set the aperture at the minimum setting (highest
number) so that if the camera is choosing the aperture, it can stop
down to the required value.
No good having it set at f2.8 if the shot needs f11.
If the lens is very old, it might have a manual iris that you have to
set yourself on the lens. The lenses that stop down automatically will
have a tiny peg on the mount that a suitable camera can operate. Gentle
pushing of this peg while looking through the lens will tell if it is
stopping down - set it wide open first.
If you have a depth of field preview button, this will also have the
same effect with the lens on the camera if the body matches up with the
lens.
I sent my canon 40D
This is a bit off the wall, I know, but have you contemplated taking the drastic step of getting the lens mended ?
