20 Most Recent
Net10 LG ULTIMATE 2 No-Contract Cell Phone Questions & Answers
Lost my pin to activate my phone
You will loose all store data doing this but you will get access to using the phone again. From the LG website:
1. Power down the phone then remove/reinsert the battery to ensure that the device is completely off
2. Press and hold the following keys for 10 seconds: Volume Down + Home Button + Power Button. Release all 3 keys when the Android Recovery Menu pops up
3. Press Volume Down to scroll down and highlight "wipe data/factory reset"
4. Press the Menu Button to select
5. Press Volume Down to scroll down and highlight "Yes - Delete All User Data".
6. Press the Menu Button to select
7. After data wipe is complete simply highlight "reboot system now" and select it by pressing the Menu Button.
3/13/2015 3:09:32 PM •
Net10 LG...
Answered
on Mar 13, 2015
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
24 hours ago
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
2 days ago
