20 Most Recent VIZIO M701d A3R 70 Inch 1080p Smart Questions & Answers
2answers
I have a Vizio M701D-A3 TV that has white horizontal lines scrolling across the entire screen.
My TV has a green line..anyone knows what I need to do to fix it?
1/30/2019 12:52:22 PM • VIZIO M701d A3R... • Answered on Jan 30, 2019
Ok i have a Vizio m701d-a3r and the image dies slowly. I've seen broken lcd and test before this is not physical damage, i know it's a board but I need help finding out which board
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
3/30/2017 11:00:25 PM • VIZIO M701d A3R... • Answered on Mar 30, 2017
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
8/21/2016 6:06:01 AM • VIZIO M701d A3R... • Answered on Aug 21, 2016
I have a Vizio M701d-A3 with single line across the top half of my screen, it appears over top of the menu when displayed. The line is not black but changes color with the picture. What's the problem?
12/8/2015 8:00:35 AM • VIZIO M701d A3R... • Answered on Dec 08, 2015
My Vizio TV has dark spot top left corner
Hi Brandon, I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
4/8/2015 4:42:49 PM • VIZIO M701d A3R... • Answered on Apr 08, 2015
Vizio V705-H1 started having display issues. The background seems okay but words have tracers.
Check Connections: Ensure that all cables connecting your TV to external devices (such as your cable box or gaming console) are securely plugged in. Loose connections can cause display anomalies. Test Different Devices or Apps: Try using other devices or apps with your TV to see if the issue persists. If the TV's menu looks fine but a specific device is causing trouble, that device might be the culprit. Adjust Picture Settings: Navigate to the picture settings by pressing the 'Menu' button on your remote. Experiment with different picture modes. Sometimes a minor adjustment can resolve display problems. Soft Power Cycle: Unplug your TV from the power source. Press and hold the power button on the TV for about 3-5 seconds (this helps drain any residual power). Plug the TV back in and turn it on. Some TVs also have a 'Soft Power Cycle' option in their settings menu, so check there too. As you have tried a reset, that takes us to the options of contacting Vizio support and/or your warranty.
4/19/2024 11:14:37 PM • Vizio Televison... • Answered on Apr 19, 2024
Vizio all in one computer VIZIO CA-27 voltage and part number for subwoofer/power supply replacement
The power supply/subwoofer for the VIZIO CA-27 series all-in-one PCs is identified by the part number 715G6960-P02-001-002S or ADTVE1825AC71. The power supply connects to the motherboard via a proprietary dual jack Audio/Power cable. I couldn't find specific voltage details for the subwoofer/power supply in the available resources. For precise information, I recommend checking the user manual or contacting VIZIO customer support directly.
3/9/2024 5:42:30 AM • Vizio Televison... • Answered on Mar 09, 2024
How to see the time on my Vizio TV
No model number so generic advice only. Google 'vizio (model) manual'. ..
2/17/2024 10:59:24 PM • Vizio Televison... • Answered on Feb 17, 2024
Living solution code to program to a Vizio
RC: Living Solutions (or Innovage) jumbo universal ...
Remote Central https://www.remotecentral.com > rc-remote > thread Jun 10, 2007 - Hold the device button you want to program for 3 seconds & release. Push & release the power button & the red light will remain lit. Push the ... Living Solutions Jumbo remote need codes - RC 5 posts Jan 18, 2008 RC: Living Solutions Jumbo URC - Remote Central 6 posts Jun 20, 2011 More results from www.remotecentral.com
Remote Codes / Universal Remote
Vizio https://support.vizio.com > article > Remote-Codes-Un... Remote Codes / Universal Remote ; 2 Digit TV Remote Codes 19 ; 3 Digit TV Remote Codes 502 627 004 113 505 011 ; 4 Digit TV Remote Codes 1758 0178 1756 0128 0117 Missing: Living ‎ solution
How to Program a Living Solutions Universal Remote
Techwalla https://www.techwalla.com > Tech Support > How To Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc.
1/30/2024 5:06:51 AM • Vizio Televison... • Answered on Jan 30, 2024
Having trouble with my Vizio E500i-A1 WiFi connection
Reboot the Router. Power cycle it and the television for 5 minutes by removing the wall plugs.
USER MANUAL - Model: E500i-A1
Vizio https://cdn.vizio.com > manuals > e500ia1_2ma... PDF It can be connected to your home network with a Wired or Wireless connection. Connecting to a Wired Network (Best). 1. Connect an Ethernet cable to your router ... 66 pages ..
1/15/2024 12:01:59 AM • Vizio Televison... • Answered on Jan 15, 2024
Why is my Vizio TV stuck on mute.
The one logo is coming from the set top box that is supplying the signal, cable box, satellite box, Android box etc. Look for Mute on that remote, or cut the power to all your devices by removing the wall plugs. Wait 15 minutes and plug back in. ..
1/7/2024 9:45:42 PM • Vizio Televison... • Answered on Jan 07, 2024
Vizio powers on see logo then shuts off after factory reset worked perfectly fine before reset
Bad LED strip lights, bad capacitors or bad diodes.
1/5/2024 8:10:18 PM • Vizio Televison... • Answered on Jan 05, 2024
2answers
My Vizio E601i-A3 will not let me do anything other functions besides turn on! Then it says no signal
Press the INPUT button on the remote control to select a different input source. If you are using cable TV, satellite, or antenna connected directly to the TV, scan for channels See page 51 of user manual. UM_E601iA3E.pdf (vizio.com)
12/14/2023 9:20:09 PM • Vizio Televison... • Answered on Dec 14, 2023
VIZIO M701d A3R 70 Inch 1080p Smart Logo
11 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
ok vizio m701d a3r image dies slowly ve
  • Televison & Video
