20 Most Recent Samsung HCL652W 65" Rear Projection Television Questions & Answers
HCL652W picture faded will bulb replacement fix this
I would say that it is not worth replacing the bulbs. I had a similar experience with an old rear projection TV like that and I just cleaned all the dust out of it as well as I could. i cleaned the back of the screen, the mirror that the image reflects off of, and the bulbs themselves. I used a dry micro fiber cloth so as not to scratch anything. doing this might help you some, but if it is working and it is bright enough for you after a few minutes, I would just live with it until you can upgrade to a newer TV.
8/31/2012 6:19:18 PM • Samsung HCL652W... • Answered on Aug 31, 2012
Ihi i have a samsung
Sounds like you need a convergence board. Problem is there might be some transistors that you need as well. I've had a similar issue. Most places will cost $300+ to replace what might be a $15 part. Also there are 2 transistors in there that need to be replaced at the same time (once one goes the other is likely to as well). I would suggest calling Sears to fix it. They charge much less for the visit ($99 min charge) and will replace both parts at the same time.
Sorry I know that's not a true answer on how to replace the convergence board or other parts but mucking around in a rear project tv is a good way to get shocked. Those TV's hold a lot of charge even after unplugging.
http://www.searshomeservices.com/televisions/repair
3/3/2011 8:45:23 PM • Samsung HCL652W... • Answered on Mar 03, 2011
HOW TO INSTALL THE OS INTO THE COMPUTER? \
How to install the OS onto the computer; Click this link and please follow the instructions carefully; http://www.ehow.com/how_4424376_install-operating-system-computer.html OR this http://www.computerhope.com/issues/ch000647.htm For any query, email me to; [email protected] Good Luck!
6/30/2010 4:14:21 PM • Samsung HCL652W... • Answered on Jun 30, 2010
Double vision dropped to the left about a half
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
10/18/2009 1:47:36 AM • Samsung HCL652W... • Answered on Oct 18, 2009
Samsung dlp tv won't show picture when powered on.
Hi, you need to replace the color wheel, very common problem with your set, video-tek
3/26/2009 8:16:31 PM • Samsung HCL652W... • Answered on Mar 26, 2009
The TV turns on and off after a few seconds and repeats itself.
There could be quite a few things that would cause the set not to power up. I dont have the service manual, however you can get a copy of the service manual at the following link for your model. As thats the only proper way to be able to check for the proper voltages to determine whats wrong with the set.
Heres the link.
http://servicemanuals.vstore.ca/
11/26/2008 10:59:44 PM • Samsung HCL652W... • Answered on Nov 26, 2008
HCL652W
Your convergence ICs are defective and quite possibly the burning smell was likely some of the convergence Resistors burning. Its actually not that exspensive of a repair. you can get a brand new Sub deflection board for your set for 232.00 at the following link and that will fix your set and you just put the new board in. The site will also provide you with free on line tech support to assist you with installing the new board. you need the P54 Sub deflection board. Its available at the following link.
6/14/2008 12:01:12 AM • Samsung HCL652W... • Answered on Jun 14, 2008
Hdtv 1080i
youre having a problem with the power supply. you will probably need a service manual to figure it out. Let me know if you want a link to purchase the service manual and get free tech support.
4/22/2008 9:37:37 PM • Samsung HCL652W... • Answered on Apr 22, 2008
Upgrading?
virtual server
1/24/2008 3:15:22 PM • Samsung HCL652W... • Answered on Jan 24, 2008
Why is my Samsung plasma tv screen becoming dark suddenly meanwhile it's on and still functioning
Hello. You can check HDMI cable in this case. If you're using an HDMI port that's not working well or has been damaged, it could result in a darker-than-usual screen. If you switch the cable or change devices and the TV is at a regular brightness, this is the case.
4/16/2024 4:37:19 PM • Samsung... • Answered 6 hours ago
2answers
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM • Samsung... • Answered 2 days ago
Samsung plasma tv repair PN51F5300BFXZA
All I can advise is to take it to an authorised Samsung repair shop. A list is available on the Samsung web site.
4/7/2024 8:20:50 AM • Samsung... • Answered on Apr 07, 2024
2answers
Samsung VHS VR8360C - if i use a three colour av cable on the VHS end and go to an HDMI connector at LG tv end will this work or do I need a converter?
The old yellow, red, white RCA cables are analogue signals, while HDMI cables only carry data. They are in no way compatible. You can buy active conversion boxes that will convert analog to digital, but simple cables cannot work
3/23/2024 10:44:12 PM • Samsung... • Answered on Mar 23, 2024
Remote code for Samsung remote to LG tv
It can't be done. The Samsung remote will be single frequency for that Samsung device only and the LG remote for that television (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 3:17:28 PM • Samsung... • Answered on Mar 19, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead. What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame. It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM • Samsung... • Answered on Feb 05, 2024
Samsung HCL652W 65" Rear Projection Television Logo
Popular Tags
17 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
hcl652w picture faded will bulb
  • Televison & Video
