20 Most Recent Sylvania SDVD1332 13" Portable DVD Player Questions & Answers
contact selling location and ask them
Sylvania... | Answered on Jun 27, 2019
A codec is a digitized set of instructions inside the computer that allows the TV or player to decipher the signal coming in, if you don't have that codec you can't play the SD. Sorry you are out of luck here.
Sylvania... | Answered on Nov 03, 2016
spares and repairs don't appear to be available. $105 on Amazon
Amazon com Sylvania SDVD1332 13 3 Inch Swivel Screen Portable DVD Player...
Sylvania... | Answered on Feb 20, 2016
Take it back to the SONY STORE, and exercise the WARRANTY to get it replaced. Take one of the "bad" DVD disks along with you, to demonstrate the problem.
Sylvania... | Answered on Feb 14, 2015
Consider using 'auto search' on Motorola.
how ?
Turn on your TV and point the remote at TV during setup
1. Press and hold SETUP until the LED blinks twice
2. Press the TV POWER key.
3. Aim the remote at your TV and press and hold down the OK key.
4. Release the key when the TV turns off and setup is complete.
Sylvania... | Answered on Jan 07, 2020
consider using 'auto search' on Motorola.
how ?
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Sylvania... | Answered on Dec 16, 2019
Curtis International which made the Sylvania clock radio no longer has any support for its legacy electronics. ManualsLib has manuals for several Sylvania clock radio models here: https://www.manualslib.com/brand/sylvania/clock-radio.html . They have a link for the SCR1388B, https://www.manualslib.com/manual/944856/Sylvania.html . This document doesn't list the SCR1388B on the cover page. However, the two clock radios are probably similar enough that the manual will help you use your clock radio. If this manual doesn't provide enough details, please check some of the other manuals listed at the first link above.
I hope this helps. ManualsLib does provide an option to get the manual as a PDF. See the Download button near the top of the page. You will need to go through some CAPTCHA checks to download the file as a PDF.
Sylvania... | Answered on Dec 13, 2019
Google (sylvania)(DV220SL8)(manual) without parens.
Sylvania... | Answered on Dec 03, 2019
Copy any video file like AVI, MP4, MKV,WMV to USB drive, plug the USB drive and select USB and play it, should play movies
Sylvania... | Answered on Nov 30, 2019
Hi Elsie-
If you do not have the remote, you can change inputs by doing the following:
Changing inputs Inputs are selected by using a number of methods, depending on the model of your Sylvania TV. Switching inputs is usually accomplished by pressing the "Input Select" button on the remote. Each press will simply cycle through each available input on your TV. If no remote is available, the front panel has a button that matches the function on the remote. This button is located on the bottom-right side of the TV and doubles as the "Enter" button when accessing onscreen menus.
Hope this helps.
Sylvania... | Answered on Nov 27, 2019
You maybe able to get a region free code for your player from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Sylvania... | Answered on Oct 31, 2019
You may also try this method to solve can't play MP4 on DVD player from http://www.idealshare.net/video-converter/solution-on-mp4-wont-play-on-dvd-player.html
Sylvania... | Answered on Oct 16, 2019
To keep it short, that is the way most tvs are wired nowadays, so you are out of luck. You are limited even on Bluetooth connections to only two headphone sets. There are some ways around it though if your tv sound output is going to a decent receiver with its own speakers.
Sylvania... | Answered on Oct 03, 2019
Sylvania SDVD1332 13" Portable DVD Player Logo
6 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
bought sylvania dvd use due wrong region
  • Televison & Video
