20 Most Recent Samsung PCJ522R 52" Rear Projection Television Questions & Answers
Samsung rear projection tv will not turn on
my tv samsung pcj522r no power
11/12/2019 3:05:00 AM • Samsung PCJ522R... • Answered on Nov 12, 2019
My 50” Samsung DLP (model HLN5065W1X) has 2
It is a common problem for the Samsung DLP HDTV, the problem is that the color wheel is going to go bad. The only way to fix it is to replace the defective color wheel.
6/2/2017 6:26:39 PM • Samsung PCJ522R... • Answered on Jun 02, 2017
How toalign horizontal picture for samsung pcj522r
Use the arrow button from the universal remote.
7/14/2014 11:51:51 AM • Samsung PCJ522R... • Answered on Jul 14, 2014
Focus hitachi 60fx32b was watching this tv and it
Try to plug it into a different electrical socket and try it without any extension cords or power strips (sometimes the socket or extension cord is to blame)
10/19/2013 12:26:55 AM • Samsung PCJ522R... • Answered on Oct 19, 2013
Cant change video mode back to tv mode
take ya camera phone turn on the camera take the tv remote and point it to the phone camera lens look in the screen if u see the light from remote flashing as u press video/tv button the button is hence the remote is ok if the remote button is faulty on video it wont flash on screen if so press the tv/av on tv and u are good to go if the tv doesnt respond then the tv programmer ic is mulfunctioning and needs replacement, u may check the memory chip on tv too for mulfunctions
7/14/2013 8:36:54 PM • Samsung PCJ522R... • Answered on Jul 14, 2013
52inch projection screen television has only red and green colors and its difficult to see the picture.
If the picture looks 3d with lines bowed it may be a convergence problem---go into the customer menu and call up convergence and at least look.
8/27/2012 11:36:18 PM • Samsung PCJ522R... • Answered on Aug 27, 2012
SAMSUNG PCJ522R, 2000 MODEL.
The crt coolant tanks should be full all the way to the plug. Its a special CRT coolant which has to be installed. The circuit boards will also need to be cleaned and possibly require the components that were in contact with the coolant resoldered.
7/11/2011 1:16:46 PM • Samsung PCJ522R... • Answered on Jul 11, 2011
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
6/24/2011 1:44:35 AM • Samsung PCJ522R... • Answered on Jun 24, 2011
FRONT PANEL LOCKED ON SAMSUNG
Hello
Press remote buttons in the following sequence [ Power Off =>Mute => 8 => 2 => 4 => Power On]. This will unlock all the settings of your TV to original factory settings. Panel lock also will be unlocked. OK.
6/16/2011 3:21:43 AM • Samsung PCJ522R... • Answered on Jun 16, 2011
My 50" samsung projection tv
Your power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
5/13/2011 1:43:47 PM • Samsung PCJ522R... • Answered on May 13, 2011
Our Samsung Tantus PCJ522R is displaying a
Distorted color picture is due to failure of convergence output section and most probably convergence output chips gone bad that need to be replaced by local tv repairmen.
Since tv is an old model so I would recommend to buy new tv instead of spending money on repairing it.
Hope these info will help you.
Thanks.
2/19/2011 1:31:00 AM • Samsung PCJ522R... • Answered on Feb 19, 2011
The television wont turn on
wish ko lang gusto ko sanang mkuha address nyo kc gusto ko pong mg sent ng letter asap thnk
2/3/2011 3:29:26 PM • Samsung PCJ522R... • Answered on Feb 03, 2011
Has a yellow tint
this caused by your tv color IC, change it with new one, contact service center if you cant do it by your self
1/18/2011 1:55:41 AM • Samsung PCJ522R... • Answered on Jan 18, 2011
I have a 47" rear
This is usually due to a leaking CRT. Or picture tube oxidation in the cooling liquid. Definatly not a job to be performed in the home. The cooling liquid needs to be changed in all three picture tubes. Cleaned inside the jugs and replacement gaskets. Gennerally about 60 to 85 dollars each.
often, the fluid leaks onto the power supply or sweep module and causes other problems.
1/17/2011 8:14:17 PM • Samsung PCJ522R... • Answered on Jan 17, 2011
TV MADE A LOUD "POP" NOSIE AND THEN SCREEN WENT
Hell k_sopata
If the display isn't working and according to the conditions you described yes it is the picture tube. You could contact Samsung and get a replacement for it.
1/10/2011 7:13:59 PM • Samsung PCJ522R... • Answered on Jan 10, 2011
My buttons do not work on the tv or remote.
Hi ibvcnd,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
Make sure the set is plugged in the outlet and has power to it.
Try the MENU button on the front of the TV.
Then if still nothing, post back and let me know.
We will start from this point.
Thanks for choosing FixYa.
John
1/5/2011 10:56:07 PM • Samsung PCJ522R... • Answered on Jan 05, 2011
Distorted deflection waves in screen, power to
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
6/14/2010 1:18:38 AM • Samsung PCJ522R... • Answered on Jun 14, 2010
Samsung PCJ522R 52" Rear Projection Television Logo
83 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
toalign horizontal picture samsung
  • Televison & Video
