20 Most Recent Samsung PCN5425R 54" Rear Projection Television Questions & Answers
Horizontal lines can be cause by many things. One of which is the convergence module. $130.00 is a little high for something that can be caused by other things as well.
Samsung PCN5425R... | Answered on Oct 21, 2019
Useing remote by pressing (info-menu-mute-power) turn off tv and press this bottons.you will get reset option on screen Thank you
Samsung PCN5425R... | Answered on Dec 10, 2013
Very easy repair....Just replace the convergence amp board part# BP95-00142E (about $80) It includes both convergence IC's and associated components (Five connectors,one screw,easy access)no soldering...
Samsung PCN5425R... | Answered on Jul 05, 2011
You don't have a color wheel in this model. There is probably a fuse blown that you missed or a resistor in the circuit outside the convergence IC's (STK 392-040). Did you press the perfect focus in the convergence part of the menu?
Samsung PCN5425R... | Answered on Jun 24, 2011
If it is rear projection set it uses either two of the STK-392-020 OR STK-392-040 CHIPS FOR CONVERGENCE OUTPUT.
BOTH WILL HAVE TO BE REPLACED; NOTE THAT THESE SETS ALSO HAVE "PICO" FUSES ON THE BOARD FOR EACH CHIP--no movement means one of the fuses is blown because the chip shorted.
This can be a do it yourself repair if you are handy; total parts cost if the parts purchased on Ebay is under 30 dollars.
Let me know if I can assist you and if you have any questions reply to the posting here.
REGARDS, SD TECH
Samsung PCN5425R... | Answered on Mar 31, 2011
Yes,this is 100% convergence problems,it dead.The tv colors lines R,G,B mis alignments any parts of the screen,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergence board,must have these parts to be replaced on it to solved the tv picture convergence problems.Try website like Tvrepairworld.com,might can still buy a whole refurbish convergence board to do the replacement.The Samsung/Akai DLP Tvs used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Samsung PCN5425R... | Answered on Dec 26, 2010
Lamp is nearing end of life and needs replacing.
Samsung PCN5425R... | Answered on Nov 25, 2010
I hope due to dusty inside your TV at switch panel its may happens like this or the rubber pad inside at switch part my collapse...... which results high volume suddely
Samsung PCN5425R... | Answered on Oct 22, 2010
This unit does not have a lamp inside. It is a CRT Projection unit. What is the symptom of your problem?
Samsung PCN5425R... | Answered on Aug 31, 2010
iF It only does it from the box either the cables are bad (unlikely) or problem is coming from box.
Two things to do: unplug box and let it reboot.
Have provider bring a new box to correct problem; component is Red, Green, Blue video with info---one messed up and bingo.
If not on regular cable the set does not know what is hooked up to it.
Get another box and get back on line.
SD TECH
Samsung PCN5425R... | Answered on Aug 20, 2010
3 blinks means that the pwer source is in protected mode becuase the high tension output is shorted - most likely the horizontal main deflection transistor has failed. Since usually this failure also damages all the connected components you should replace the entire board. Here it is
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-BP94-00230A.aspx?srccode=&cpncode=
Samsung PCN5425R... | Answered on Aug 06, 2010
If one of the 3 bulbs goes out you will have color distortion. I have also seen in some older Sony rear projections heavy loss of focus can be the result of a dead bulb.
Samsung PCN5425R... | Answered on Jul 11, 2010
Without any power going to the TV, it's likely that the power supply has been fried. If you feel comfortable opening the set, you should check where the power plug goes into the power supply and locate the fuse. The fuse is a small glass tube with metal rings at either end. If you take the fuse out of the holder and hold it up to a light, you can see whether or not the filament (the little wire) is still connected. If it isn't, and if the area's black or brown, then the fuse is blown and needs to be replaced.
Samsung PCN5425R... | Answered on Jun 05, 2010
You probably also have a bad digital convergence box. I have a tip at https://www.fixya.com/support/r4273935-replace_digital_convergence_box which explains how to fix the problem and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Samsung PCN5425R... | Answered on May 09, 2010
What ur "PROBLEMS" discirbe that first.Than i can help u determine which the boards $75 or $26 that will work for U.
Samsung PCN5425R... | Answered on Apr 22, 2010
well, at this time using the remote to adjust is not doing any good anymore. should replace the IC and it's not that expensive. go to Partstore.com and they should have a convergence board for about $76 or you could buy the parts and put it together by soldering.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttps://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Samsung PCN5425R... | Answered on Apr 03, 2010
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Samsung PCN5425R... | Answered on Mar 25, 2010
Samsung PCN5425R 54" Rear Projection Television Logo
115 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung dlp
  • Televison & Video
