20 Most Recent
Samsung HCM5525W 55" Rear Projection Television Questions & Answers
Wher is fuse fd102s located
check fuse FD802A on the power supply board it is also feeding the -30 volt line. FD102S is on the convergence board 3.5 amp pico fuse
Wher is part # fd102s
both FD101S and FD102S are on the convergence board they are identified as small green or tan resistor shaped components (pico fuse) 3.5 amp 125 volt
I have a SAMSUNG HLP5674W and it has begun to make
pull the light assembly out clean it with a vacuum and some pressurized air spray and place it back in the TV, while it is out check the fans on either the inside or in the removable assembly for damage or other interference in operation...If this doent help dissemble/remove the rear of the enclosure ( 6-10 screws) and clean the insides carefully and then turn the tv on - being careful not to be touching ANYthing and see if you locate the culprit.....
Fuse Location PT-52LCX66
Follow the power cord into the set--it goes almost directly to the ac line fuse inside the set.
Manual focus location
It will not correct for convergence problems and almost never needs to be adjusted---what is issue with the set?
Tv color is too red
the red screen control if located can be turned down until the picture is normal.
My Samsung HCM5525W won't turn on
A few possible reasons--the usual if dead is power supply or set is in protective shut down--means someone has to open, check for voltages in and out of the power supply.The "its happening more and more" suggests a more sinister possible issue.This set uses 3 picture tubes and is well known for the coolant in one or more (seen one with all three leaking) leaking the Glycol--as more leaks it gets worse.If someone opens the set and looks for signs on the wires above the main boards and on the boards below (will be if there seen in first 6 inches or so from front of set--signs of what looks like even a small amount of clear liquid--Glycol has leaked.DO NOT if you see signs of it touch it---very toxic and more toxic than antifreeze which it is except more concentrated.It causes all sorts of problems as it dissolves metal leads and parts.Let me know (you have to look carefully!) if you find this.
Curved red lies at top/bottom with some double vision in lines
This is from another fixya article but its relevant to your problem.
Your TV most likely has one or more possible problems. Problem #1: Convergence Chip Failure ( common problem )Here are some of the most common symptoms and example photos of a convergence problem
- Screen looks 3D
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
Here is a quick test....Using your original remote go-to the tv settings then goto the convergence section.Try to adjust the red and then the blue convergence.You should be able to move them up, down, left, and right.If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem. Solution #1You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc. Problem #2 CRT Fluid is CloudyProjection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages. Picture of a set that needs the fluid changed. TV set after fluid change Solution #2What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Samsung hcm 5525w
If this set is new, a problem like this would be covered by warranty. If it is no longer under warranty, locate the convergence ICs which will be large black ICs attacked to a heatsink. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace the ICs. These should be marked STKxxx.
Keep me posted,
Dan
I have a couple issues.
The tv have a problems known as a convergence pictures problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes all of these problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Hi. My Samsung SP-43 J8HF
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
