20 Most Recent
Samsung HLN437W 43" Rear Projection HDTV Questions & Answers
I got this tv (Samsung #hln437wx/xaa) used
There is a power supply that supplies the circuit board plus the lamp, because of hi power there may need someone to look at the circuit board and maybe repair it
Should not cost that much
Lost color
It could be the color processor module, could be locked up, or your tuner is going bad. First thing to do is unplug the AC cord, from the the AC outlet for about 40 Minutes and that will reset the color processor. if you still have problems, then bypass the tuner, and go directly to the video input with a DVD player, or Video game player "360 x box" or anything that you can hook up to the video input. Make sure to put your TV in Video mode, if you have color now , than you have a bad tuner, if it is still black and white, than in is the color module that is bad, or your color control is turn all the way down.
Lamp and temp lite flashing
The lamp is drawing to much current and it will get to the point that the set will not come on, the lamp needs replace, and you can go to partstore.com and get a lamp and instll it.That will take care of your problem
I have a samsung HCP4752W
theas units have a comen problem of the color weel failing, first check the lamp then the wheel and all fans.
Samsung HCP4752W convergence board?
I couldn't decide whether or not to attack the IC Chips or the whole board, so I took out my S&W model 59 and pumped 11 9mm rounds into the whole chassis! Sets works as new as long as 'new' means comes with 11 bullet holes in chassis.
I have a Samsung HLN437W DLP TV I turn it on and in about a minute there is no picture or sound and you have to turn it off you have to unplug it
That problem is usually have 2 causes..Its either power supply board or main board..Please take this steps on how to determine the problem:1. Open the back cover.2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..4. If the power supply output is normal..The problem could be on the main board...5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..Hope this solution will be helpful..Thanks for using fixya...
I have a samsung hln437n
Could be a slightly loose lamp connection and/or slightly loose lamp module - especially if you
have big trucks or railway tracks near your place (like me). Try powering down the TV set, use the
instructions that came with your TV to remove the lamp module, then simply re-install the lamp
module (also known as "reseating the lamp module").
If the buzzing noise persists, then
its coming from a component near the lamp (such as the power supply).
If there's a transformer in the power supply that's buzzing, then its about to fail.
I am presently working on
That sounds like one of 2 things:
- Color wheel
- Light engine
Color wheel because of the losing
color, but the light engine because of the picture freeze. It's very
difficult to judge since I can't be there to see it. I'm leaning toward
the light engine though. The only fix is to replace the DMD board, or
entire light engine.
Hi, the tv comes on ok for about 15 seconds then
This
could be caused by lots of things.
Possible
causes that come to mind are.
1. TV is over heating -
2. Power
cord not securely plugged in the wall outlet.
3.lamp
door cover, which could trigger the auto-shutdown switch - you can fix this on
your self by correctly resetting the door cover witch.
4.The
power board is Malfunctioning
You may
want a local company come out and take a look because it's difficult to
pinpoint the cause without looking at it. You can find a local shop google tv repair in google maps, or
call 800-SAMSUNG for an authorized technician.
Is there a trick to
There are certain locks that hold the board either attached to the other boards or the chassis itself depending on where it got stuck. Please get me an image of the area where you suspect is the lock and I will tell you how to remove it.
Sai.
