20 Most Recent
Samsung HL-P5663W 56" Rear Projection HDTV Questions & Answers
Our samsung DL-P5663W PROJECTION TV
Hello
Normally, DLP Tvs must turn on silently. If your DLP projection TV makes a loud sound [you haven't specified anything about the sound you hear from it, either from its speaker or from inside]; it should be checked and get retified soon, otherwise, there is a chance to get DLP module damaged. If it does happen, it means that your DLP TV is out, because, the cost of DLP will be very high. Get the fault retified as fast as you can. Never switch on your TV, till this fault has been rectifed. you haven't given here enough details of fault, and so, I can't send you a solution to you. OK.
3/22/2011 3:25:59 PM •
Samsung...
Answered
on Mar 22, 2011
Buzzing sound
It is a problem with the flyback transformer...R u good at electrical circuits?If yes you can unsolder the old one re-solder the new one and check it for high-voltage..
If you are not good at this i advice you not to open it coz there's always a risk of high voltage..Anyways if you want to get it repaired it should cost you aroun 75-100$
10/18/2007 11:42:53 PM •
Samsung...
Answered
on Oct 18, 2007
Cleaning the TV
On each side of the set is a round access panel.
Remove the oblong style cover to get to the screw that holds the round door on.
You should have access through the hole once the hole cover is removed.
Don't spray anything inside and cleaning should be done with a dry soft cloth.
If you need further instruction, reply to this post.
8/12/2007 3:59:53 PM •
Samsung...
Answered
on Aug 12, 2007
Samsung dlp dnie
just from personal exp the easiest thing to do may fix or at least make it better. if u see puffed and leaky caps on power supply replace capacitors. if really dusty clean. both previously mentioned and both helped me. my tv was completely dead and replacing caps got it to power back up and work. it takes two trys to come on but works great so far. then i cleaned every nook and cranny with a small vacuum hose and different size/angle brushes that could be attached to hose. i only took out the psb board with caps and didnt touch anything in there that i could mess up. just cleaning helped enhance the colors. right now this is the best picture ive had on a tv and it was completly dead when i got it.
SAMSUNG TV HL-85687W picture is dim
(Please check your model number - it appears to be incorrect, I believe it's HL-S5687W) 1) How old is the lamp? (how many hours on it)2) Is the lamp an original equipment lamp, or aftermarket?It's either the Lamp itself (it's not common for a sudden reduction in brightness), -or- the Lamp Ballast has gone bad. This is the power source for the Lamp, and although they usually die completely when they do go, sometimes they will act just as you have described... they fail into a "low power" mode.If the lamp IS an original mfr lamp, and if it's nowhere close to being near "end of life", then I'd say it's likely the Ballast.Prices for the original Samsung lamp run around $100 onamazon and others.The Ballast p/n BP47-00037A has a cost of around $50 to $100 online. Google those p/n in "Shopping"The Ballast can be replaced without great knowledge, but will require some dis-assembly, and CARE.WARNING - Dangerous, and even lethal voltages are present inside your TV set. Do not attempt this unless you are trained in these kinds of repairs. Leave the TV unplugged for several hours (or preferably a full day) before attempting such repairs.
