20 Most Recent SanDisk Sansa e130 MP3 Player Questions & Answers
7answers
Will not turn on with new battery
Well it depends where you are, are you in New Zealand? Try reseting the player if it has one other wise take it to an electronic shop to get it fix.
10/1/2019 5:30:20 PM • SanDisk Sansa... • Answered on Oct 01, 2019
6answers
Sandisk e130
Get out the battery and let the device "calm down" without any source of power for 5-10 minutes. After that push the menu/start button, hold down for 30 or more seconds and holding down, insert the battery. It has to reset the power circuitry and should help.
4/11/2019 3:34:03 AM • SanDisk Sansa... • Answered on Apr 11, 2019
Why is my battery draining so fast?
you must hear only two songs per day.
6/30/2018 1:12:44 AM • SanDisk Sansa... • Answered on Jun 30, 2018
0answers
5answers
Can't open SD camera card--error message.
1. Do not save any new file to memory card.2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.3. Download a recovery software, recommended one is this photo recovery (simply because i was using it and it worked)SD Card Photo Recovery4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.You may refer to this tutorialRecover files from SD Cardhope this helps.
8/26/2014 6:07:07 PM • SanDisk Sansa... • Answered on Aug 26, 2014
Photos says UnsupportedMediaFormat
You need to use the supplied Sansa Media Converter program to convert and transfer photos (and videos). If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
1/28/2011 6:46:11 AM • SanDisk Sansa... • Answered on Jan 28, 2011
It wont Play
throw your unit...
1/12/2011 5:11:10 AM • SanDisk Sansa... • Answered on Jan 12, 2011
I have ripped a 2 disc set of The Phantom of the
Try renaming the tracks with sequential numbers, this might fix this.
1/8/2011 5:34:46 PM • SanDisk Sansa... • Answered on Jan 08, 2011
How do i get the player to read mp3s from an sd
It won't. However, if they're on a microSD card, then they need to be in a folder named "MUSIC". Videos and photos will need to be in the internal memory, the Sansa will not read them from a card.
10/6/2010 5:18:14 PM • SanDisk Sansa... • Answered on Oct 06, 2010
E130 need to replace the screen
in service center it may be costly
7/19/2010 6:43:03 PM • SanDisk Sansa... • Answered on Jul 19, 2010
No funciona
BUENO no se que es lo que no funciona per muchos aparatos hoy en dia funcionan un dia oh no funcionaron del todo ...es necesario cargar toda la noche antes de usar cualquiera que usa bateria ...lo mejor es buscar otra cosa que muchos usan asi uno esa seguro que funciona..
2/5/2010 1:32:56 AM • SanDisk Sansa... • Answered on Feb 05, 2010
Hi, I have a Sandisk Sansa e130 512 mb mp3 player.
As far as I can see from the manual the e100 series player only supports up to 2 GB memory SD cards, see page 8 (=7) of the manual:
http://mp3support.sandisk.com/downloads/um/sansa-e100-userguide.pdf
Formatting the SD card of 2 GB should be in FAT format, see:
http://kb.sandisk.com/app/answers/detail/a_id/312/related/1/kw/sd/p/555%2C662%2C697%2C699/r_id/101834
12/24/2009 1:34:59 AM • SanDisk Sansa... • Answered on Dec 24, 2009
How to download music from itunes
you will need the itunes programme which you can find just by going to itunes.com and on the page you can download the programme, and once installed you set up and account and search music and thn download any music you like, cheers
12/12/2009 4:31:51 PM • SanDisk Sansa... • Answered on Dec 12, 2009
SanDisk Sansa e130 MP3 Player Logo
Popular Tags
75 questions posted
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
open sd camera card error message
  • Audio Players & Recorders
