20 Most Recent
Engines & Components for Toyota Camry V6 Questions & Answers
Reset toyota camry v6 ecu
if u want to reset the ECU just unplug the battery for 5-10 mints then plug it back by this the memory in the ecu is erased , if not u have to reset it from a scanner
10/14/2015 4:23:08 AM •
Engines &...
Answered
on Oct 14, 2015
Oil leaks in the 3VZ V6
The older 3VZ V6 engine will often leak oil after 100000 km or so. This can drip on the exhaust and smoke and smell awful. The leaks happen from the rear (right bank) cam cover gasket, distributor o-ring seal, and oil filter adapter bracket to block o-ring. When replacing these it is best to use genuine Toyota gaskets and seals, as the aftermarket parts don't fit as well, and don't last as long.
Como se activa la alarma de una toyota tundra
tengo una 2007 toyota tundra lumited 5.7,pero no me dieron el cotrol ,solo la llave y quisiera saber si con solo ka llave podria programar un nuevo control con el mismo sisteme de seguridad que tiene
Car security light won't stop flashing while driving?
Are you disarming the system with a remote or disabling by inserting the key. On some vehicles you may have a remote control key fob and a master key that works with no buttons, it is a straightforward key with no buttons that temporarily disarms the vehicles alarm for use, it does not fully disarm. When the alarm system is armed through the remote it can only be disarmed through the remote via the transmisson of a coded signal. Have you got these 2 different kinds of keys?
Please add detail and resubmit the query
