20 Most Recent
Nu Mark Numark Dxm06 DJ Mixer With 12 Effects System Questions & Answers
Numark cue mixing
to change headphone track, use the cue slider which is located on the right of the control panel above the right chanel treble control and below the cue gain control. chanel 1 or 2 can be selected or in the middle for a mix of both tracks just like the cross fader.
My right channel upfader on
Yes take it to your local numark dealer and they will send it out or fix it right there. sounds like the faders blown.
The headphone jack broke. It is kind of pushed
I repaired mine when that happened.... you have you unscrew all the screws on the top plare there is like 5 or 6 silver ones..Remove faders (2 volume 1 headphone) then remove the top plate. Then unscrew the the black screws on the side and front of the mixer... NOW THIS PART IS IMPORTANT..from the corners of the mixer there will be a little lifts carefully lift the top of the mixer up JUST A LITTLE BIT... have someone hold it or just rest it diagonally so you can unscrew the jack from the back MIC unless you were able to salvage the jack from the headphone if that silver and black piece are gone your going to have to borrow it from the mic... dont worry the mic will still be functional because its better set in that the headphone jack... now use the outside piece and bring the headphone component to the front where its suppose to be so you can screw the 2 back together.. then put every back together in a reverse order and you should be fine.... if you have anymore questions email me at
[email protected]
Can i use any power adapter with the same
Yes you can use any adapter with output AC 9Volts/1,5Amper. In case of difficulty at the market use any one adapter with output AC 9Volts/more than 1,5Amper. It will just be a little bigger. These details are already printed in the back of your mixer, near the power input jack.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feedback
Is your audio equiptment grounded and all levels at a decent level with no over gain
I have a numark cdn 88 just change the transport
Chances are that you didn't reassemble the unit correctly or damaged a ribbon cable or limit sensor. Re check your work. Pay attention to small circuit board attached to the spin motor RF310T-11400. De-solder the small circuit board on the 2 motors..and apply 12v to the spin motor. See if it spins with no dead spots on start up. when asseembled, motor will only operate and spin up to the proper RPM only if loading is successful and tray is fully closed ..etc. Hope this Helps. I have a CDN-88 in my shop for skipping issues on both CD players. so I saw your problem here while doing research. Good Luck,
Thanks, Dillon, Trace Electronics, Barrie, ON, Canada.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
