20 Most Recent
Xerox CopyCentre C118 Copier Questions & Answers
How can I by pass the user on Xerox C118?
Enter Diagnostics. Hold down the 0 button and then press the Start button. Press the logon/out button on the control panel, select system settings, then changing password, then press enter. Set password, default is 11111, power off and back on.
Error code c1-300
Open the left cover and check for obstructions in the paper path (paper,foreign substances).
Check the paper tray bottom plate (the metal one) on which the paper stack is sitting and ensure that there is at least a 1mm gap between the metal edge and the plastic wall to the left.
Do you have the same problem when feeding from all trays?
If that happens from all trays then a technitian needs to check the machine. The best case scenario is that the registration sensor is blocked or damaged. The worst case scenario is that the MCU board needs to be replaced.
Xerox c118 copy is not centered
Enter diagnostic: press "0" then "Start", enter System settings->CE Settings->MFC->Regist, enter 102 to adjust x-axis or 101 - y-axis, adjustment range x (-24 to 127), y (-72 to 72). 24 bit = 1mm. Good luck
