20 Most Recent
HP Omni 120-1124 All-in-One Desktop 1.65 GHz AMD E-450, 4 GB DDR3, 1 TB HDD, DVDARW DL, AMD Radeon HD 6320, Windows 7 Home Premium, 20" LCD Questions & Answers
How does one remove and replace the dvd drive in the HP Omni all in one 120-1124?
buy one on ebay for your PC.
most laptops have custom made drive. even the curve of the front is unique and all mounting holes unique.
the removal is not hard, just 1 screw on the bottom on most.
he service manual covers this at HP
just buying one is hard, never putting it in,.
find a screw 1 hands width from front of drive. take out that screw
there is no video of 10000000 laptop models made , some yes.
the service manual is it;.
or go to a shop ask the tech to take it out, they do in 5min flat.
end story
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types
Hp supply central pin connected to the 19V power
- Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
- Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
- Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
- Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
- Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
Look for the driver for my Pc media center M7000 product M7682fr system number RF893AA ?
Visit the HP Support Website:
Go to the official HP support website at HP Customer Support.
Enter Your Product Details:
Enter the product name "Media Center M7000" and locate the specific model or product number. In your case, you've provided the system number RF893AA, which is also known as the product number.
Locate Drivers and Downloads:
Once you've identified your product, navigate to the "Software, Drivers, and Firmware" section.
Choose Your Operating System:
Select your operating system (e.g., Windows) and its version (e.g., Windows 7, 8, 10).
Find and Download Drivers:
Look for the drivers related to your PC's components, such as graphics, audio, network, etc. Download the required drivers to your computer.
Install the Drivers:
After downloading the drivers, run the installation files and follow the on-screen instructions to install them.
Restart Your PC:
After the installation is complete, restart your PC to apply the changes.
If you face difficulties finding the specific drivers for your model or if your PC is quite old and HP no longer provides drivers for the chosen operating system, you may need to consider using default drivers that come with the operating system or upgrading your operating system.
