20 Most Recent
Zanussi ZBB28650SA White 268 l Fridge Freezer Bottom Freezer, A Energy Rating Questions & Answers
Zanussi zx97/5W Fridge keeps getting warm...
If your Zanussi ZX97/5W fridge keeps getting warm, there could be a few possible causes:
- Thermostat malfunction: The thermostat controls the temperature inside the fridge. If it is malfunctioning, it may not be able to maintain the correct temperature, causing the fridge to get warm.
- Dirty condenser coils: The condenser coils are responsible for removing heat from the fridge. If they are dirty, they will not be able to function properly, causing the fridge to get warm.
- Door seal issue: If the door seal is damaged or not sealing properly, it can allow warm air to enter the fridge, causing the temperature to rise.
- Fan motor issue: The fan motor is responsible for circulating the air inside the fridge. If it is not working properly, it may not be able to circulate the air, causing the temperature to rise.
- Temperature control issue: If the temperature control is not set correctly, the fridge will not be able to maintain the correct temperature.
7/18/2023 9:57:51 PM •
Zanussi...
Answered
on Jul 18, 2023
Zanussi ZX97/5SI fridge/freezer. Fridge part no
If the fridge part of your Zanussi ZX97/5SI fridge/freezer is no longer keeping cool, while the freezer part is still working fine, there could be a few possible causes:
- Air circulation problem: If the air is not circulating properly inside the fridge, it may not be able to maintain the correct temperature. This could be caused by a dirty or blocked air vent, a malfunctioning fan motor, or a problem with the door seal.
- Evaporator coils are iced up: The evaporator coils are responsible for removing heat from the fridge. If they become iced up, they will not be able to function properly, causing the fridge to get warm.
- Compressor issue: The compressor is responsible for pumping refrigerant through the cooling system. If the compressor is not working properly, it may not be able to pump refrigerant through the system, causing the fridge to get warm.
- A malfunctioning control board: The control board is responsible for managing the functions of the refrigerator, if it's malfunctioning it may cause the fridge not to maintain the correct temperature.
1/25/2023 5:13:30 PM •
Zanussi...
Answered
on Jan 25, 2023
How can I get to the evaporator fan in zanussi fridge freezer ZX97/5SI
Odds are the fan is in the freezer side...For some reason the cold air isn't getting to the freezer. In the back of the freeze part shoud be a channel that the cold air blows thru to cool the refer. Either the fan is not working...or working slow. or something is blocking the path of cold air. Dig into it. Shoud be an easy fix.
11/22/2022 5:01:33 PM •
Zanussi...
Answered
on Nov 22, 2022
